After a power-failure this evening I’m suddenly getting an Insteon Authentication Error only in HomeAssistant. I am able to use the Insteon App wtihout any problem, but all the automations that involve Insteon are broken. To state the obvious I’ve tried restarting multiple times.
Insteon Hub version 1019
Log files show:
2021-08-16 21:06:15 ERROR (MainThread) [homeassistant.components.insteon] Could not connect to Insteon modem
2021-08-16 21:06:18 ERROR (MainThread) [homeassistant.components.konnected.panel] Exception trying to get panel status: Cannot connect to host 192.168.86.43:9123 ssl:default [Connect call failed ('192.168.86.43', 9123)]
2021-08-16 21:06:18 ERROR (MainThread) [homeassistant.components.konnected.panel] Exception trying to get panel status: Cannot connect to host 192.168.86.48:9123 ssl:default [Connect call failed ('192.168.86.48', 9123)]
2021-08-16 21:06:25 ERROR (MainThread) [pyinsteon.protocol.http_reader_writer] Athentication error, check your configuration
2021-08-16 21:06:25 ERROR (MainThread) [pyinsteon.protocol.http_reader_writer] If configuration is correct and restart the Hub
2021-08-16 21:06:25 ERROR (MainThread) [pyinsteon.protocol.http_reader_writer] System must be restared to reconnect to hub
2021-08-16 21:06:25 ERROR (MainThread) [homeassistant.components.insteon] Could not connect to Insteon modem
Any tips?
