I am in the process of switching to using Home Assistant thanks to Insteon going belly up. I have 37 devices all set up and they all seem to work so far, except the “sensor” part of the I/O Linc. I rigged up my own garage door opener using the I/O Linc and it worked fine with the hub.
But HA is not changing sensor status. It only ever says closed. Should this be fixed in my Synology HA integration? (Refreshing the page doesn’t change the status)
… time passes …
Here is what is in the configuration.yaml (as far as I can figure out):
"address": "41f1d7",
"cat": 7,
"subcat": 0,
"firmware": 0,
"engine_version": 2,
"aldb_status": 1,
"aldb": {
"4095": {
"memory": 4095,
"in_use": true,
"controller": true,
"high_water_mark": false,
"bit5": true,
"bit4": false,
"group": 1,
"target": "2ad4ad",
"data1": 3,
"data2": 0,
"data3": 0
"4087": {
"memory": 4087,
"in_use": true,
"controller": false,
"bit5": true,
"bit4": false,
"group": 7,
"target": "2ad4ad",
"data1": 0,
"data2": 0,
"data3": 0
"4079": {
"memory": 4079,
"in_use": true,
"bit5": true,
"bit4": false,
"group": 6,
"target": "3f4873",
"data1": 0,
"data2": 0,
"data3": 0
"4063": {
"memory": 4063,
"in_use": true,
"controller": true,
"bit5": true,
"bit4": false,
"group": 1,
"target": "49e167",
"data1": 3,
"data2": 0,
"data3": 0
"4055": {
"memory": 4055,
"in_use": true,
"bit5": true,
"bit4": false,
"group": 0,
"target": "49e167",
"data1": 0,
"data2": 0,
"data3": 0
"4047": {
"memory": 4047,
"in_use": true,
"bit5": true,
"bit4": false,
"group": 24,
"target": "49e167",
"data1": 0,
"data2": 0,
"data3": 0
"4039": {
"memory": 4039,
"in_use": true,
"bit5": true,
"bit4": false,
"group": 1,
"target": "49e167",
"data1": 0,
"data2": 0,
"data3": 0
"4031": {
"memory": 4031,
"in_use": false,
"high_water_mark": true,
"bit5": false,
"bit4": false,
"group": 0,
"target": "000000",
"data1": 0,
"data2": 0,
"data3": 0
"operating_flags": {
"program_lock_on": false,
"blink_on_tx_on": true,
"relay_on_sense_on": false,
"momentary_on": true,
"momentary_on_off_trigger": false,
"x10_off": false,
"sense_sends_off": false,
"momentary_follow_sense": true
"properties": {
"prescaler": 1,
"delay": 20,
"x10_house": 32,
"x10_unit": 0
I’m wondering about these parts:
"relay_on_sense_on": false, <====?
"momentary_on_off_trigger": false, <===?
"x10_off": false,
"sense_sends_off": false, <====?
