Insteon Device Override
I know where to get the device address, but where do I find the category and subcategory?
I found a pdf dated 2008 from Insteon that lists all the devices and categories and subcategories and productIds - most of them appear to be correct but some are missing. I need the category and subcategory for a fanlinc. I will update with the URL to the document when I get back to the dev machine. there are also some scripts to dump the contents of the database – I know this was a older post but I hope you’ve found them.
I just went through adding my insteon devices to home assistant and needed to do the device override. My devices were imported into home assistant but none of them were correctly identified so there were no attributes associated with the device and they couldn’t be controlled. If you are using the insteon app you can find the address, category, and sub-category on the edit device page.
The first 2 digits of device details is the category, and the next 2 digits are the sub-category. The insteon ID is the device address. I found the insteon manual listing several device classes, but I couldn’t find my outlets or a couple of other devices listed here.
Hope this help anyone trying to bring up the insteon integration.
INSTEON Device Categories and Product Keys
