Insteon keypad scenes not working
I have a 6 button Insteon keypad with on, off, a, b, c, d keys. I programmed button A to toggle 5 Insteon switches in an area or my home. I press A and in HA I can see that device is ON, I press it again and all lights turn off and in HA shows keypad A is off, great.
However at any point it in HA I toggle to on or off all it does is change the LED color of the keypad buttons from on to off or vice versa but doesn’t actually change the associated switches so no actual lights change state.
I have several such keypads and all exhibit the same undesired behavior and I’m on 2022.5
I know its an old post, but did you ever find a solution to this? I’m using keypads to control fanlincs in ceiling fans. local works fine and I can toggle in HA manually on the fanlinc, but if I toggle the button on the keypad in HA the button turns on, but the fan does not respond. Started creating automations, but that might be a mess. 3 automations for fan speed and then 3 more to turn off with conditions of the others not being on. Multiply that by the number of keypads/fanlincs in the house. Gotta be a better way!
