I wanted to know if and when they loose heartbeats so I can replace their batteries. I created a group with all heartbeats and created an alarm. To test, I removed the battery in one of the leak sensor. It’s been 48 hours and I never received the alarm (the heartbeat never went to “problem” - stays at "OK). I thought the sensors were being polled once a day for heartbeats. If that’s the case, why does the sensor still shows as having a heartbeat with its battery removed?
Do you have a similar experience? Any troubleshooting I can try?
So I don’t know what the ‘phantom’ sensor is, but it’s showing as active and doesn’t correspond as far as I can tell with anything I have set up, and my two actual leak sensors aren’t in there. Btw, do the leak sensors show as dead in the mobile app?
I have the same problem. I’m unable to get any indication that the heartbeat has not been detected. The way I tested it was to remove the battery from one of my sensors and allow over 25+ hrs to pass. The heartbeat indicator still shows “OK” when I know that’s not possible. Also setup the alert and do not get any notification. It would be nice if I could 1) test without taking a couple of days … i.e reduce the heartbeat timeout to 5 minutes so that I can at least see that the automation/trigger is working (since it wouldn’t get another heartbeat in 5 minutes). 2) simulate the arrive of an Insteon heartbeat so that I could test the indicator updating from a failed state to a good “OK” state.
BTW:
I’m using Insteon Leak Detector Model 2852-222 Rev 3.0
Home Assistant Core 2022.5.4 Home Assistant Supervisor 2022.05.1
Home Assistant OS 7.6 Kernel version 5.10.108 Agent version 1.2.1
