I go to Settings → Devices & Services → Insteon → Configure → Add Device
I click on the button on the remote and it says it was added
but it never shows up in the device list how can I use this why doesn’t it show up here? I’ve tried multiple times and it never shows in the device list.
I’m using the Powerlink USB modem. I also just recently added a Zigbee Coordinator so I don’t know if that is causing an issue.
I want to use the remote as a trigger for turning on/off a switch for a light.
FYI - I’m fairly new to HomeAssistant but I am a programmer with 30+ years of experience so I should be able to figure this out.
I was able to create other automations and scenes and even a helper toggle that I would like to trigger from this remove but I can’t figure out how to use this remote or where I can even find it after it says it was added.
Has anyone gotten these 2342-2 mini remotes to work? I can’t get any trigger from them at all.
I have HA running in a virtual machine. The 2 devices show up in my device list (eventually) with what I believe is the correct type => 2342-222 (0x00, 0x1a) and 2444A2WH8 (0x00, 0x12) . I’ve tried entering a manual event as shown by danhoeger above, but nothing works.
Jim Shipman
I’m working on this now, too. If I watch the Events in Developer Tools, it does this.
event_type: insteon.button_on
address: 000000 # my mini-remote address
group: 3
button: c
origin: LOCAL
time_fired: "2025-07-18T03:12:09.136483+00:00"
context:
parent_id: null
user_id: null
So, to make it generic, I removed the group and button and did dual triggers for on and off to make this test automation which works. Sometimes it doesn’t register, but I have the same problem using a Hub 2 with HomeSeer, so I think that’s on the Insteon Hub and not HA.
alias: Insteon Mini-Remote
description: ""
triggers:
- event_type: insteon.button_on
event_data:
address: 123456 # put your mini-remote address here
trigger: event
- event_type: insteon.button_off
event_data:
trigger: event
actions:
- action: notify.persistent_notification
metadata: {}
message: >-
Insteon group {{ trigger.event.data.group }}, button {{
trigger.event.data.button | upper }} {{ trigger.event.event_type }} pressed.
This works on one of my remotes, but the other does not emit any events even though it is firing events on HomeSeer through the Hub 2. Both are Insteon model 2342-2. After re-enrolling the other remote, it now fires, too.
I’ve also coded a “handler” that can call separate scripts or automations for each button + on/off, or you could put code right into the handler.
