I tried and the device is still not updating in the HA UI.
I did the service call with the parameter you said and the green light on the plm started to flash. I hit the set button and tested. The device status in the UI did not update when I toggled the physical device.
If I just hit the set button the plm the green light does not flash.
I held the set button for a few seconds and the green light started to flash. I then tried the service call again. The green light was still flashing so I hit set. Tested again and no joy.
Assuming you pressed the SET button on the device can you send me the link table for the PLM and the device. Here is what needs to be done.
Make sure your log level is info. In your configuration.yaml file add the following lines (a restart is required to make any changes effective):
logger:
default: warn
logs:
homeassistant.components.insteon_plm: info
From the Services tool under Developer Tools run the insteon_plm.print_im_all_link_database service. It does not require any parameters in the Service Data field.
You should now have a table printed at the bottom of the home-assistant.log file. Please send me the contents of that table. It should look like this:
2018-07-19 09:52:44 INFO (SyncWorker_1) [homeassistant.components.insteon_plm] ALDB load status is LOADED
2018-07-19 09:52:44 INFO (SyncWorker_1) [homeassistant.components.insteon_plm] RecID In Use Mode HWM Group Address Data 1 Data 2 Data 3
2018-07-19 09:52:44 INFO (SyncWorker_1) [homeassistant.components.insteon_plm] ----- ------ ---- --- ----- -------- ------ ------ ------
2018-07-19 09:52:44 INFO (SyncWorker_1) [homeassistant.components.insteon_plm] 004e Y R N 8 44.89.9F 0 0 0
2018-07-19 09:52:44 INFO (SyncWorker_1) [homeassistant.components.insteon_plm] 004d Y R N 2 41.89.CF 0 0 0
2018-07-19 09:52:44 INFO (SyncWorker_1) [homeassistant.components.insteon_plm] 004c Y R N 1 44.89.9F 0 0 0
2018-07-19 09:52:44 INFO (SyncWorker_1) [homeassistant.components.insteon_plm] 004b Y C N 0 20.48.75 5 10 14
2018-07-19 09:52:44 INFO (SyncWorker_1) [homeassistant.components.insteon_plm] 004a Y C N 0 14.61.9B 2 13 56
2018-07-19 09:52:44 INFO (SyncWorker_1) [homeassistant.components.insteon_plm] 0049 Y C N 0 45.E5.15 2 47 72
2018-07-19 09:52:44 INFO (SyncWorker_1) [homeassistant.components.insteon_plm] 0048 Y C N 0 47.01.47 2 26 65
2018-07-19 09:52:44 INFO (SyncWorker_1) [homeassistant.components.insteon_plm] 0047 Y C N 0 41.89.3F 2 57 68
2018-07-19 09:52:44 INFO (SyncWorker_1) [homeassistant.components.insteon_plm] 0046 Y C N 0 33.0A.FA 2 42 67
2018-07-19 09:52:44 INFO (SyncWorker_1) [homeassistant.components.insteon_plm] 0045 Y C N 0 20.48.75 1 0 0
2018-07-19 09:52:44 INFO (SyncWorker_1) [homeassistant.components.insteon_plm] 0044 Y R N 239 20.48.75 0 0 239
2018-07-19 09:52:44 INFO (SyncWorker_1) [homeassistant.components.insteon_plm] 0043 Y R N 4 20.48.75 0 0 0
2018-07-19 09:52:44 INFO (SyncWorker_1) [homeassistant.components.insteon_plm] 0042 Y R N 3 20.48.75 0 0 0
No, I pressed the SET button on the PLM. Since the switches were already paired with the PLM when I used Vera I thought the command you gave me was to update the PLM.
Since I misunderstood, are these the steps I should try before the debugging infoā¦
Press the button on the physical switch (I think it beeps or flashes)
Call the insteon_plm.add_all_link service with the parameters: {āmodeā: āresponderā, āgroupā: 1}
Test
To be clear, the set button on the PLM is not to be pressed.
Tried a few combinations of running services and pressing buttonsā¦still no joy. Here are the logsā¦
2018-07-19 22:11:11 INFO (MainThread) [homeassistant.components.insteon_plm] Looking for PLM on /dev/ttyUSB0
2018-07-19 22:11:12 INFO (MainThread) [homeassistant.components.insteon_plm] New INSTEON PLM device: 295d4e (lightOnOff) switch
2018-07-19 22:11:12 INFO (MainThread) [homeassistant.components.insteon_plm] New INSTEON PLM device: 2969a2 (lightOnOff) switch
2018-07-19 22:11:12 INFO (MainThread) [homeassistant.components.insteon_plm] New INSTEON PLM device: 2a4cbb (lightOnOff) switch
2018-07-19 22:14:08 INFO (SyncWorker_19) [homeassistant.components.insteon_plm] ALDB load status is LOADED
2018-07-19 22:14:08 INFO (SyncWorker_19) [homeassistant.components.insteon_plm] RecID In Use Mode HWM Group Address Data 1 Data 2 Data 3
2018-07-19 22:14:08 INFO (SyncWorker_19) [homeassistant.components.insteon_plm] ----- ------ ---- ā ----- -------- ------ ------ ------
2018-07-19 22:14:08 INFO (SyncWorker_19) [homeassistant.components.insteon_plm] 0002 Y C N 1 2A.4C.BB 2 42 67
2018-07-19 22:14:08 INFO (SyncWorker_19) [homeassistant.components.insteon_plm] 0001 Y C N 1 29.69.A2 2 42 67
2018-07-19 22:14:08 INFO (SyncWorker_19) [homeassistant.components.insteon_plm] 0000 Y C N 1 29.5D.4E 2 42 67
The ALDB data shows that the links are in one direction only. The PLM can control the switch. But we need to get it so that the PLM responds to the switch. Letās try this:
I held down the SET button on the switch until the light (on the switch) started to flash. Then I held down the SET button on the PLM until itās light started to flash. The light on the PLM flashed once or twice and then stopped and then it made a āclickā sound.
No problem. Sorry it was so hard. In general the way INSTEON works is based on links. But links go in both directions. There are controllers and responders. As you would suspect, controllers control responders and responders respond to controllers. This can be short cutted by having the PLM as a controller always ask the responder for status since a responder will always respond if a controller asks for status. However, the better way is for two way links to be set up, this way the PLM is a responder to the other device (in your case a switch). This way whenever the switch state changes the PLM hears it and responds to it. Hope that helps.
I would also go with option 1 just to keep it simple. I currently use Insteon-MQTT bridge which allows Home Assistant to talk to Insteon-MQTT through Mosquito and then Insteon-MQTT will do the rest. If the new Insteon component can talk to my Insteon 2242-222 hub through a networked PLM interface, that would allow me to get rid of Insteon-MQTT bridge and Mosquito.
