I would like to schedule the led backlight on an Insteon SwitchLinc Dimmer 2477D to turn off at night and back on in the morning. I can successfully set this property via the Insteon Integration by clicking on the switch and setting the value for the led_dimmer property; and then clicking write to device via the UI. I would like to incorporate these steps into an Automation. Can someone confirm this is possible and if so please share an example yaml and/or automation.
Adding some additional context. The attached screenshot shows the Insteon panel UI and highlighted is the led_dimming property and arrow to click and write to the device - which are the steps I would like to automate.
In addition this post shows the steps to set led_dimmer at the OS level using insteon_tools:
https://community.home-assistant.io/t/new-insteon-version-for-beta-testing-do-not-use-since-this-is-now-in-0-111-and-higher/184489/290
Any advice on how to incorporate into an automation is appreciated.
Changing properties using automations is not possible at this time. It is on the roadmap, however. Sorry for that.
Thanks for working on this. I really appreciate it and look forward to it. This is about the last piece that I look forward to from the Insteon side of things with Home Assistant. Thanks again.
@teharris1 Any update on setting led_dimming by an automation or schedule?
Just adding that this would be a super useful feature. @teharris1
I also agree! It would be a super useful feature to be able to change properties via automation. Not only for led-dimming but also for On-level. At night when I hit the kitchen light dimmer switch, It goes full 100%. It needs to be on about 25% @teharris1 , Let me know if you need me to help test!
