Insteon setup questions
I’m moving an Insteon PLM over from Indigo. I’ve got about 85 devices that the UI lists and can address when the hub is plugged into the machine running Indigo, so it appears the Insteon stuff is working. I’ve plugged the hub into my HA system (Pi5 running HAOS 13.1 and Core 2024.8.3 and configured the USB connection in the Insteon add-on. It is listing no devices in its UI (other than the PLM). The All-Link DB is empty and in reading through the forums, this seemed like a good place to start. My two options under the 3-dots are “Read from Device” and “Add Default links” - alternately there is “Create ALDB Record” at the bottom right.
Are any of these a good next step, or am I barking up the wrong tree as it were?
Thanks!
