Insteon Thermostat 2441TH
would anyone know if there is an update to this? I have 5 Insteon thermostats and would love to see them on HA. I am using the isy994.
If you’re using the ISY: please install the ISY994 custom-component from HACS to have access to the thermostats.
Still working through the updates to the original PyISY module which is holding me out from pushing the updates to Home Assistant for right now, but the custom component is workng great as a drop-in replacement with additional features for now.
@teharris1, do you still have the branch of Home Assistant that you had it working for 2441TH? I tried to follow the link (https://github.com/teharris1/home-assistant/tree/thermostat) you posted last year and it returns 404. Thanks!
I do not have it any longer but I can recreate it. I am also working on a new version of Insteon that has a lot of new features if you are interested in being a Guinee pig. BTW, do you use a hub or a plm?
Is the thermostat supported in the new version? I’m currently using PLM with my HA. I have 2 PLMs, a hub and a couple of Rasperry Pis laying around.
Is this the branch that contains your new Insteon changes?
https://github.com/teharris1/home-assistant/commits/pyinsteon
I have created a new version that includes the thermostat but it requires a new library underneath it. Here is the link to the HA version you need:
You also need this library installed:
https://github.com/teharris1/pyinsteon/tree/release1
I have done a lot of testing of this solution and it is in very good shape. BUT, please keep in mind this is still under development so bugs will definitely exist. Also, the Thermostat is a very flaky device with all kinds of weird behaviors. For example, I found out during development it will only send status to one modem at a time.
If you do test it please provide feedback using this post:
