For VirtualBox create a new virtual machine, select “Other Linux (64Bit), assign it at least 2 GB of memory and “Use an existing virtual hard disk file”, select the VDI file from above, afterwards edit the “Settings” of the VM and go “System” then Motherboard and Enable EFI, then “Network” “Adapter 1” Bridged and your adapter.
I downloaded the VDI file from above as instructed. However, I am unable to use the file. I get the error:
Could not get the storage format of the medium ‘C:\Users\USER\Downloads\hassos_ova-4.13.vdi.gz’ (VERR_NOT_SUPPORTED).
I suspect it is because the file is *.gz but I’m just following the instructions as provided and I’m stuck as to how to proceed.
Flash the downloaded image to an SD card using balenaEtcher. If using a Pi, we recommend at least a 32 GB SD card to avoid running out of space.
Load the appliance image into your virtual machine software. (Note: You are free to assign as much resources as you wish to the VM, please assign enough based on your add-on needs)
The docs may be a bit confusing there, however I think they are right. These are 2 different steps for different hardware, the first is for the pi, the second is for any VM image. But I agree that this is not really clear and they could need an overhaul, but who will do this? …
For the device images: Flash the downloaded image to an SD card using balenaEtcher. If using a Pi, we recommend at least a 32 GB SD card to avoid running out of space.
For the virtual appliance images: Load the appliance image into your virtual machine software. (Note: You are free to assign as much resources as you wish to the VM, please assign enough based on your add-on needs)
Does BalenaEtcher decompress *.gz files? When I followed the instructions before for the pi, I didn’t have to unzip the *.gz file. I think that led to my confusion in understanding for the virtual machine process that it needed to be decompressed.
His reply was for me and I don’t feel offened or anything like this. It was probably even a hint for me to do it myself, as I’m a very frequent forum poster
Tinkerer is an admin, he’s not a member of the core home assistant dev team, meaning all his valuable contributions and the help he provides has been done in his free time.
Yes and no, Balena can work with certain compressed format such as bzip, gzip or xz but it doesn’t work with .tar archives.
The Pi image is an .img.gz file, which is supported by Balena.
It wasn’t directed at you… it was directed at the person I’d quoted (or anybody else who knew the answer).
Sometimes the docs don’t make sense because they were written by people who knew how it all worked, and so didn’t include things because they were assumed. That’s unhelpful, but it needs people like you to come along and go these instructions are broken so that somebody who can work out what’s missing can update it.
It’s not uncommon for people to identify what needs doing, but then wait for somebody else to do it, hence my poke that somebody shouldn’t wait for somebody else to do it.
