I’m setting up an automation for my son’s bedroom where if there is no button presses on his hue dimmer for the past 30 minutes, it will turn off the light.
I’m getting an error message, which I guess has something to do with whether the state is an integer or a string.
The error message reads:
File “”, line 1, in top-level template code
TypeError: ‘>’ not supported between instances of ‘str’ and ‘int’
I’ve based my code on this thread:
So here’s what I’ve put together:
The sensors
- platform: time_date
display_options:
- 'date_time'
sensors:
jakobdimmer_counter:
value_template: '{% if states.sensor.jakobdimmer_updated.last_updated is undefined %}{{"00:00:00"}}{% else %}{{ ((as_timestamp(states.sensor.date__time.last_updated)-as_timestamp(states.sensor.jakobdimmer_updated.last_updated))|int) }}{% endif %}'
entity_id:
- sensor.date__time
And then the automation:
- id: "Jakob-lys autoav" # Skru av lyset til Jakob etter 30 minutters inaktivitet
alias: "Jakoblys av på dagtid"
platform: state
entity_id: sensor.jakobdimmer_updated
condition:
condition: and
conditions:
- condition: time
after: '08:00:00'
before: '19:00:00'
service: script.jakob_lys_autoav
Finally, the script:
jakob_lys_autoav:
sequence:
- wait_template: “{{ states.sensor.jakobdimmer_counter.state > 10 }}”
- service: light.turn_off
entity_id: light.jakobs_rom
transition: 0
So what I can understand is that using > on a string doesn't work. How then do I tell the system that it is in fact an integer?
