I’m trying to integrate with a Integra Ri3 power monitor.
I’ve added the below to my config file, and generally no errors in the log I can see, but the values are always reported as zero.
The unit has been configured 38400 8 bit 1 stop bit no parity.
modbus:
- name: MCR_PowerMeter
type: serial
baudrate: 38400
bytesize: 8
method: rtu
parity: N
port: /dev/ttyUSB0
stopbits: 1
close_comm_on_error: true
retry_on_empty: true
retries: 10
sensors:
- name: L1toN_Voltage
scan_interval: 10
slave: 1
count: 1
unit_of_measurement: 'V'
data_type: float16
address: 0x00
input_type: holding
- name: L2toN_Voltage
scan_interval: 10
slave: 1
count: 1
input_type: holding
data_type: float16
address: 0x02
- name: L3toN_Voltage
scan_interval: 10
slave: 1
count: 1
input_type: holding
data_type: float16
address: 0x04
