I created a step-by-step guide on how to integrate DTU Homilies into Home Assistant. I hope it helps.
Solar Data DTU W100 Ger2 And other DTU
Here’s the step by step.
1 Configure your MQTT if it is not configured or install it if it is not mine was like this
MQTT
http://homeassistant.local:8123/hassio/addon/core_mosquitto/info
In the bottom corner Add-ons Store
Install and let’s go to adjustments. Click on the 3 dots in the upper corner Edit with yaml `
logins:
- username: Vinicius #Create Your username of choice
password: 12345 # Create a password
require_certificate: false
certfile: fullchain.pem
keyfile: privkey.pem
customize:
active: false
folder: mosquitto
Save this because we will need it.
In the graphical interface it must be like this: the ports used by MQTT must be released in the Firewall and I released them in the Router as UTP TCP. I released input and output 1883, 1884, 8883, 8884 so that MQTT can talk to the programs.
Save and start MQTT.
1 install Hoymiles DTU Solar: Home Assistant Add-on there are two one stable and one not stable
I installed both of them.
Installing the Hoymiles DTU Solar: Home Assistant Add-on
Follow the step-by-step instructions in the documentation on how to install or use the Android app Fing. After installing, go to settings >
Log in to your DTU W100 and get the IP address it is operating on >
Now set a password, as the default is admin - admin
Suppose the password is admin password 123456
To know the default port, do not change 10081
Hoymiles DTU Solar: Home Assistant Add-on adjustment
Settings.yaml in the 3 points above
dtu:
host: 192.168.100.? #IP of your DTU W100
port: 10081 # Port always released is port 10081
username: admin #User who placed it in the DTU
password: 123456 #User who placed it in the DTU
app: {}
app_mode_active: {}
app_mode_passive: {}
mqtt:
broker: 192.168.100.? # MQTT IP is the same as your home assistant
port: 1883
username: Vinicius # Name you chose in MQTT
password: 12345 # Password you chose in your MQTT
MQTT IP is the same as your HA uses EX> http://< Your IP> l:8123/
Repeat the steps installing the same add-ons because one version is stable and the other is not and I don’t know which one is working because the programmers stopped and the other continued. There will be no conflict, it will be just another piece of junk that doesn’t work in your HA. But one works and the other doesn’t. >
Repeat the steps above in settings and just copy and paste the configurations.yml
Now let’s go to the second program
I installed both of them too because it’s the same thing with the first one, one is stable and the other doesn’t work. >
Install
Go to settings >>>
3 dots top how to edit settings.yml
HOYMILES_USER: Viniciusmbs # User you use to log in to your plant
HOYMILES_PASSWORD: 12345 # User you use to log in to your plant
HOYMILES_PLANT_ID: "67??" # Final ID of your plant
Read_meter_data: true
External_MQTT_Server: true
MQTT_Host: 192.168.100.??? # IP of your MQTT is the same as Home Assistant
MQTT_User: vinicius # user created for your MQTT
MQTT_Pass: 123456 # password created for your MQTT
MQTT_TLS: false
MQTT_TLS_PORT: "8883"
DEVELOPERS_MODE: false
LOG_LEVEL: INFO
LOG_TO_FILE: false
FILE_PATH: hoymiles.log
Your plant number and password are in S-Miles Cloud - Hoymiles Power Electronics Inc.
The plant number is in
S-Miles Cloud - Hoymiles Power Electronics Inc.??? << Plant number
HOYMILES_USER: Viniciusmbs # User you use to log in. in your plant
HOYMILES_PASSWORD: 12345 # Username used to log in to your plant
Save and start the add-on
Do the same steps with the same add-on as the first one, copy and paste the configurations.yaml from the first one, but in this documentation
To access the data
Go to http://homeassistant.local:8123/config/integrations/integration/mqtt
http://homeassistant.local:8123/config/devices/device/187ea61d0800ff1237c5fdfbaa204453
The sensors will be there and just make your card I used this card
If you did everything right and just copy this card of mine, this will appear E
