Integrate 2FA with Authentik and Traefik
Hello
I am about to switch from openHAB to HASS and I already struggle to integrate it with my Authentik / Traefik combination. I found the guide: Integrate with Home Assistant | authentik
I have already set up a domain wide forward auth and also included HASS there now as an external service. Since it is a docker-based installation i also tried using labels for traefik as i do in some other containers but that leaves me with the problem of not being able to use network mode: host - which i need for mdns etc.
I have to sign in with my username / pw again after a successfull authentication with authentik - is there a way around that?
I have some problems setting up o-auth - specifically spotify but i am sure it will adapt to other services as well. i added https://hass.myfqdn/auth/external/callback to my developer dashboad and copied the secret and id and i get an invalid url error - i think i need an exception for my authentik middleware. can you help me there? i have no idea on how to achieve this.
Thank you
docker-compose.yml:
networks:
  frontend:
    external: true
  backend:
    external: true
services:
  homeassistant:
    image: ghcr.io/home-assistant/home-assistant:stable
    container_name: homeassistant
    environment:
      - PUID=1000       #matches docker (vm) user  (in termianl: id- -u 'USER')
      - PGID=1000
      - TZ=Europe/Berlin
    volumes:
      - ./config:/config
    network_mode: host
    # networks:
    #   - frontend
    # ports:
    #   - 8123:8123 #optional
    # labels:
    #   - traefik.enable=true
    #   - traefik.http.services.hass.loadbalancer.server.port=8123
    #   - traefik.http.routers.hass.rule=Host(`hass.${DOMAIN}`)
    #   - traefik.http.routers.hass.entrypoints=websecure
    #   - traefik.http.routers.hass.tls=true
    #   - traefik.http.routers.hass.tls.certresolver=cloudflare
      #- traefik.http.routers.hass.middlewares=authentik-middleware@file
    # devices
    #   - /path/to/device:/path/to/device #optional
    restart: unless-stopped
configuration.yml:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
homeassistant:
  external_url: "https://hass.myfqdn"
  internal_url: "http://192.168.1.112:8123"
  # auth_providers:
  #   - type: header
  #     name: Authentik
http:
  use_x_forwarded_for: true
  trusted_proxies:
    - 172.19.0.0/16
    - 192.168.1.0/24 # Traefik runs externally (not in the docker network)
  ip_ban_enabled: true
  login_attempts_threshold: 20
in traefik:
external.yml:
http:
   hass:
      rule: "Host(`hass.mydomain`)"
      service: hass
      entryPoints:
        - websecure
      tls:
        certResolver: cloudflare
  services:
    hass:
      loadBalancer:
      #  serversTransport: insecureTransport
        servers:
          - url: "http://192.168.1.112:8123"
the authentik.yml:
http:
  middlewares:
    authentik-middleware:
      forwardAuth:
        address: http://authentik-server:9000/outpost.goauthentik.io/auth/traefik
        trustForwardHeader: true
        authResponseHeaders:
          - X-authentik-username
          - X-authentik-groups
          - X-authentik-email
          - X-authentik-name
          - X-authentik-uid
          - X-authentik-jwt
          - X-authentik-meta-jwks
          - X-authentik-meta-outpost
          - X-authentik-meta-provider
          - X-authentik-meta-app
          - X-authentik-meta-version
