Integrate 868MHz central heating
Hello, I have a central floor heating system with wireless thermostats. The vendor is Altech but not able to find a whole lot of information about them. It uses 868MHz for communication. Is there any way I can pick up that communication and control it through home assistant? I have been looking at things like RFLink and RFPlayer but I am unsure whether they can connect.
Currently RFlink does not support it, according to there device list.
Though you could enable debug en send the output to the developer which will then try to put in the next release of RFlink.
HTH
Hi:) I have the same problem - did you find a solution?
Still cant find any solution for same problem
