Hello
I’m running home assistant on a raspberry pi 3b+.
I want to control my onkyo receiver next to the raspi. There is this command line tool for raspberry pi which does exactly that.
It’s python code which outputs the data on a GPIO pin that connects to the receiver.
How would I go about running this tool in home assistant?
Maybe this is interesting to other people too, because this tool allows you to control RI (Remote Interactive) compatible devices.
Why not just use HA Onkyo integration? Controls both zone volume/power/source/maybe more but I not care beyond that
I think HDMI CEC or other HA integration will do same with less trouble but honestly depend on how you using your system so maybe that will be better for you.
I think my Onkyo TX-8050 does not support ‘network standby’ so this wont be able to turn on the receiver. Also the onkyo only connects via LAN and I have no acces close by.
Thanks for the reply!
edit: Just tried it. Can confirm TX-8050 can not be turned on via network.
