Integrate Hue lamp from Alexa to Hassio
Hello all, I have one Philips Hue lamp registred to Echo Show (so I don’t use Philips Bridge but Zigbee gateway integrated in Echo Show), how can I show the lamp on Hassio?
I integrated Alexa to HA, but I can see only the echo dot/show in list.
Thank you
Integration with Alexa doesn’t work that way. It doesn’t bring Alexa devices over to Home Assistant.
Yes, now I know that :slight_smile:
But is there a solution (except using Hue Bridge for sure) ?
Not that I can see. Sell the Hue stuff and get something supported in HA?
You can buy a cc2531 stick and use zigbee2mqtt
Ok, thank you, I’ll integrate the Hue Bridge, I believe is the fastest way!
