I am making some progress with the Kogan RGBW bulbs. I used the template settings for the Luminea ZX-2832 E27 RGBW Bulb here and now have the RGB channels working, and used Setoption19 1 to have HA auto-discover the bulb.
A couple of problems remain, the sliders for Cool/Warm work more like a dimmer and are backwards - at 100% Cool, the bulb is fully Warm in colour, at 100% Warm the bulb is dimmed to an off state.
The brightness of the RGB colours is a little dim as well, they do display accurately though based on the colour wheel selector. So a few things left to sort out and debug, but progress is progress.
I have tried the Mirabella template, does not work as well as the Luminea does.
This has the RGB working and has the brightness slider work independently of the color temp slider. The color temp slider now works (somewhat) in the correct way. Full warm makes the bulb 100% warm, full cool dims the bulb to about 5% brightness and no white light.
Iâm starting to think these bulbs fake white light using the RGBs and only have warm LEDs for ânormalâ white bulb color.
Still happy to donate one to someone in Aus who might have more knowledge on how to work these things out than I do.
I like the Kogan app because it doesnât need the cloud (ie I can control the wifi switch with my phone via the home router over the local network even if the router has no internet connection). If I swap to tasmota will that cloud independence be preserved?
Most likely you can still flash them, but you need to open them and solder some wires to them. There are some other treads around here that explain it.
I only have white with temperature bulbs, so no RGBW, but it should be easy enough from the code where to add. Added test.py top allow debugging, let me know if you need a hand.
Also worth noting my bulbs operate up to 1000 for brightness for colour temp, so had to change pytuya.
