Dielee
(Linus Dietz)
October 18, 2018, 12:46pm
1
Hello guys,
is it possible to integrate a sensor graph (lovelace) into a card with other entities ?
I tryed to manage this, but can’t get it work.
My config:
- type: entities
title: Heizung
show_header_toggle: false
entities:
- climate.wohnzimmer
- sensor.wohnzimmer_heating
- entity: sensor.wohnzimmer_humidity
name: Wohnzimmer Luftfeuchtigkeit
type: sensor
- sensor.wohnzimmer_power
- sensor.wohnzimmer_temperature
- sensor.yweather_temperature
- input_boolean.heizung
Lovelace UI showing this:
Ideas are much appreciated!
Thanks!
lolouk44
(lolouk44)
October 18, 2018, 1:06pm
2
you probably need a vertical stack with 2 cards, one for your entities and one for the graph
Dielee
(Linus Dietz)
October 18, 2018, 1:17pm
5
Yes thanks, i know this site. But this gave me a new tab on top of my ha…
I want to build a card on my home tab.
Something like this:
- type: vertical-stack
cards:
- type: entities
title: Any title
entities:
- entity: sensor.temperature
- type: history-graph
entities:
Dielee
(Linus Dietz)
October 19, 2018, 6:31am
7
Sadly not working…
HA gave me this:
Code:
cards:
- type: entities
title: Any
entities:
- entity: climate.wohnzimmer
- type: sensor
title: Heizung_v2
lolouk44
(lolouk44)
October 19, 2018, 8:04am
8
What’s not working? You have your entity and your graph in one big card. What exactly are you trying to achieve? Can you maybe provide a mock up picture?
Dielee
(Linus Dietz)
October 19, 2018, 8:12am
9
I want something looks like this:
lolouk44
(lolouk44)
October 19, 2018, 8:24am
10
it won’t work unless you create your own custom card.
Other thing I can think of would be a picture element but that would require you to convert your data into picture ( liike using InfluxDB and Grafana) and create a camera that pulls that picutre, then you’d set the camera to cover the picture element image and add labels for the other bits. That’s a lot of work, but not impossible
I have done something similar for my vacuum (the latter bit with the picture element, not the chart bit yet):
- type: picture-elements
image: /local/blank.png
elements:
- type: image
entity: camera.vacuum_map
camera_image: camera.vacuum_map
style:
top: 50%
left: 50%
width: 100%
height: 100%
- type: icon
icon: mdi:play
tap_action: call-service
entity: vacuum.mi_robot_vacuum
service: vacuum.start
style:
top: 95%
left: 20%
"--paper-item-icon-color": rgb(115, 122, 130)
- type: state-icon
entity: sensor.xiaomi_battery_level
service: vacuum.start_pause
style:
top: 95%
left: 10%
"--paper-item-icon-color": rgb(50, 50, 50)
- type: state-label
entity: sensor.xiaomi_cleaned_area
style:
top: 5%
left: 5%
color: rgb(255, 255, 255)
transform: translate(0%,-50%)
pointer-events: none
text-shadow: 1px 1px black
font-family: Trebuchet MS
font-size: 90%
font-weight: bold
border-left-style: solid
border-color: rgb(34, 154, 210)
background-color: rgb(54, 65, 78)
opacity: 0.8
- type: state-label
entity: sensor.xiaomi_cleaning_time
style:
top: 5%
right: 5%
font-size: 90%
font-weight: bold
opacity: 0.8
It’s still a work in progress (only created yesterday) but it should give you an idea
VDRainer
October 19, 2018, 8:25am
11
Dielee
(Linus Dietz)
October 19, 2018, 8:52am
12
Thanks, but this is to much work for such a simple result.
Dielee
(Linus Dietz)
October 19, 2018, 9:17am
13
Big THANKS ! This works like charm.
If someone looks for the same, my code:
- type: custom:vertical-stack-in-card
title: Heizung
cards:
- type: entities
entities:
- type: sensor
entity: sensor.wohnzimmer_temperature
- type: sensor
Hello It’s very good But Itry to do the same here may first card
entities:
- entity: light.spot_1
- entity: light.spot_2
- entity: light.spot_3
- entity: sensor.depuis_lu_abi
title: Chambre d'Abigaël
type: glance
here my second
type: history-graph
end: '{{ now().replace(hour=0).replace(minute=0).replace(second=0) }}'
duration:
hours: 24
entities:
- light.spot_1
and i try this
cards:
- type: glance
entities:
entities:light.spot_1
but i have a mistake on line 11 ?
Can you help me ? Thanksd
lolouk44
(lolouk44)
July 22, 2019, 8:43pm
15
which one is line 11?
What is the error message?
Also you’re using the custom:vertical-stack-in-card. Did you actually install this custom card?
Hello, yes and no i forgot to install GitHub - ofekashery/vertical-stack-in-card: 📐 Home Assistant Card: Group multiple cards into a single sleek card.
But now it’s installed I don’t have ui-lovelace.yaml and i add this line code
resources:
- url: /www/vertical-stack-in-card.js?v=0.1.3
type: js
in the top of the configurator of lovelace
But now when i try to call this card i have
No card type found
lolouk44
(lolouk44)
July 23, 2019, 10:05am
17
if you don’t have ui-lovelace.yaml, you’ll need to create it and then you’ll have to manually created your views/cards.
Check this page and this post for more info
