brunosso
(Alberto Scrofani)
April 14, 2024, 9:03am
1
Hi to all.
I setup a water flow sensor with a Wemos D1 and a Water Flow sensor mod.YF-B5.
I setup Tasmota like this GitHub - KonstantinPfeiffer/TasmotaWaterFlow
I integrate the Tasmota device inside HA, but i can see only the Counter Value.
I edit the script to create a JSON like
tele/%topic%/SENSOR {"FlowRate":%flow%,"PulseRate":%delta%,"WaterFlow":"%cflow%","Total":%liter%,"Counter":%total%}
as i see in other tasmota device i have in my house.
I think is not good enough.
This is the output of the Tasmota WebUI (all the value except the Counter1 all calculated in the script)
This is what i get in HA:
What kind of JSON i need to create, to get HA side catch all the data?
francisp
(Francis)
April 14, 2024, 10:00am
2
brunosso:
tele/%topic%/SENSOR {“FlowRate”:%flow%,“PulseRate”:%delta%,“WaterFlow”:“%cflow%”,“Total”:%liter%,“Counter”:%total%}
Do these actually get filled ? Do you see values in e.g. MQTT Explorer ?
brunosso
(Alberto Scrofani)
April 14, 2024, 10:23am
3
yes, the MQTT broker have the information
i try to add the Timestamp.
also i have the device in the tasmota/discovery topic, but i don’t have the value i want
brunosso
(Alberto Scrofani)
April 15, 2024, 7:06pm
4
Actually i add an entity to HA by configuration.yaml with following code
mqtt:
- name: "Consumo Acqua Acquedotto"
state_topic: "tele/sensore_acqua/SENSOR"
value_template: "{{ value_json.Total }}"
device_class: water
state_class: total_increasing
unit_of_measurement: L
but how can i create the entity directly into the Tasmota device, so HA can discover it automatically?
brunosso
(Alberto Scrofani)
April 15, 2024, 8:50pm
5
I think i’m almost done…
Naturally i have the topic tasmota/discovery/%macaddress%/sensors populated with the Counter1
If i add in the script the section
>J
,"Acqua":{
"FlowRate":%flow%,
"WaterFlow":%cflow%,
"Total":%liter%
the result is
but this time the JSON is not idented… maybe is only this the problem.
Did you got it running?
I also had an GAS counter which need to use a script value for calculating.
At the moment the needed value is not shown directly in the tasmota integration.
Cheers Robert
