I have setup Home-Assistant in a Kubernetes cluster. In one of the nodes of the cluster I’ve plugged the dongle and I think it’s detected by the OS, because typing lsusb shows a new device:
Bus 001 Device 003: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
I went to my Home Assistant site via port forwarding. Nothing is auto-discovered (I get no notifications) so I selected a new integration: Zigbee Home Integration. But after that, I was lost.
My model is ZBDongle-P, and that’s all I can say. I can only add that the pod running Home Assistant is the same in which the dongle is connected.
I don’t know Kubernetes (but know libvirt/Qemu), goto HA’s UI->Settings->System->Hardware->All Hardware, do you see a ttyUSB0 (or USB1)?
If not, then the USB device is likely not getting passed through
I fixed the problem. The pod I was using didn’t have the privileged: true attribute. With it, it was able to connect to the device. It was ttyUSB0 in my cluster node and mapped to the same nave in the pod.
Network based coordinators are great in use-cases where you have clustering and don’t want to be bound to a single piece of compute. Check out UZG Gateway - ZigStar UZG.
