Looks like there is a bug somewhere, it should work if you the sensor instead
Seems to only work for the binary sensor right now
Not sure what is the issue but it started working again after i restarted HA. Will investigate more
Well, how about that… I only tried the switch and the sensor as that’s how everyone else referenced their triggers, but binary sensor works for me. Let me know if you’d like any further detail!
Hey @vinteo,
Awesome work you have put into your integration.
I am interested in displaying the open sprinkler flow rate in a lovelace history card.
Unfortunately it comes out as a progress bar rather than a line graph.
I’ve read else where that this is caused due to unit_of_measurement not defined in the senor, but not sure where to go about changing that with your integration - I’m still a Home Assistant newbie.
Do you know what unit it is supposed to be based on your numbers? Litres (liters) per pulse?
In my application, I have it set to 1 pulse per litre.
Did you mean 1 litre per pulse? Sorry I don’t have flow sensor on my setup.
Yes that is correct, I use 1 litre per pulse.
There is also the option to Gal/pulse - so maybe other users might need the option to set that too.
I think the OS App does conversion from gal -> liter. Please try updating to v1.1.1 and see if it works for you now.
FIXED!
Fantastic work @vinteo, maybe next update change the description to ‘L/min’ but I’m happy to have the graph displayed correctly. Well done!
Let me know if I can help out with any testing of sorts.
Very excited about your integration - top work!
How do you get flow rate, what hardware?
I use a Cyble Sensor V2 which attaches nicely to the top of my mains water meter.
Hi vinteo, thanks a lot for this integration. It is really essential now, once IFTTT is not free anymore.
Can you please make numeric sensors for the last run water volume of each station?
Eyal
I am not sure that should be the responsibility of the integration, you could probably get that working with a combination of the the template sensor, flow rate sensor and the start/end time attributes of the station sensors with automations.
Thank you vinteo.
If no one did it before I will probably do it:
For each station whenever station status <> “idle”, accumulating flow_rate for averaging.
multiply the average flow rate by last_run.duration
Notify if water volume is not in the reasonable range for this station.
Hey Vincent
How do I stop all stations?
The doco says:
service: opensprinkler.stop
entity_id: switch.controller_name # Switches or sensors for controller
But I don’t see a switch with the “controller_name”. I assume my controller name is just opensprinkler, but there is no “switch.opensprinkler”. There is an enabler switch -> switch.opensprinkler_enabled, but this doesn’t stop all stations.
Any help appreciated
OK,
Here is my implementation.
It send once a day notification to HA app, with irrigation volume of each station.
many thanks to vinteo for the intergration.
input_number:
current_irr:
initial: 0
min: 0
max: 1000000
step: 0.1
mode: box
unit_of_measurement: 'l/m'
irr_st_1:
initial: 0
min: 0
max: 1000
step: 0.1
mode: box
unit_of_measurement: 'liter'
irr_st_2:
initial: 0
min: 0
max: 1000
step: 0.1
mode: box
irr_st_3:
initial: 0
min: 0
max: 1000
step: 0.1
mode: box
irr_st_4:
initial: 0
min: 0
max: 1000
step: 0.1
mode: box
irr_st_5:
initial: 0
min: 0
max: 1000
step: 0.1
mode: box
irr_st_6:
initial: 0
min: 0
max: 1000
step: 0.1
mode: box
irr_unknown:
initial: 0
min: 0
max: 1000
step: 0.1
mode: box
automations:
- alias: "accumulate irrigation"
platform: numeric_state
entity_id: sensor.gina_haviva_flow_rate
above: 0
repeat:
sequence:
- service: input_number.set_value
data_template:
entity_id: input_number.current_irr
value: "{{ (states('sensor.gina_haviva_flow_rate')) | multiply(0.000167)| float | round(3)}}"
#divid by (calibration fator * 6 readings per minute)
- delay: 00:00:10 #The delay is here to consumpt the time that irrigation start but sensor show 0
- choose:
- conditions:
- condition: state
entity_id: binary_sensor.st_1_station_running
state: "on"
sequence:
entity_id: input_number.irr_st_1
value: "{{(states('input_number.irr_st_1'))| float| round(1) + (states('input_number.current_irr')) | float| round(2)}}"
- conditions:
- condition: state
entity_id: binary_sensor.st_2_station_running
state: "on"
sequence:
entity_id: input_number.irr_st_2
value: "{{(states('input_number.irr_st_2'))| float| round(1) + (states('input_number.current_irr')) | float| round(1)}}"
- conditions:
- condition: state
entity_id: binary_sensor.st_3_station_running
state: "on"
sequence:
entity_id: input_number.irr_st_3
value: "{{(states('input_number.irr_st_3'))| float| round(1) + (states('input_number.current_irr')) | float| round(1)}}"
- conditions:
- condition: state
entity_id: binary_sensor.st_4_station_running
state: "on"
sequence:
entity_id: input_number.irr_st_4
value: "{{(states('input_number.irr_st_4'))| float| round(1) + (states('input_number.current_irr')) | float| round(1)}}"
- conditions:
- condition: state
entity_id: binary_sensor.st_5_station_running
state: "on"
sequence:
entity_id: input_number.irr_st_5
value: "{{(states('input_number.irr_st_5'))| float| round(1) + (states('input_number.current_irr')) | float| round(1)}}"
- conditions:
- condition: state
entity_id: binary_sensor.st_6_station_running
state: "on"
sequence:
entity_id: input_number.irr_st_6
value: "{{(states('input_number.irr_st_6'))| float| round(1) + (states('input_number.current_irr')) | float| round(1)}}"
default:
entity_id: input_number.irr_unknown
value: "{{(states('input_number.irr_unknown'))| float| round(1) + (states('input_number.current_irr')) | float| round(1)}}"
until:
condition: numeric_state
below: 0.00001
- alias: Notify irrigation
initial_state: 'on'
platform: time
at: '10:00:00'
- service: notify.mobile_app_gm1910
title: Irrigation report
message: " אחוז השקיה {{ (states('sensor.gina_haviva_water_level'))}} % \n
aaa {{ (states('input_number.irr_st_1'))| round(1)}}\n
bbb {{ (states('input_number.irr_st_2'))| round(1)}}\n
ccc {{ (states('input_number.irr_st_3'))| round(1)}}
ddd {{ (states('input_number.irr_st_4'))| round(1)}}
eee {{ (states('input_number.irr_st_5')| round(1))}}
fff {{ (states('input_number.irr_st_6'))| round(1)}}
unknown {{ (states('input_number.irr_unknown'))| round(1)}}"
value: 0
value: 0
value: 0
value: 0
value: 0
value: 0
value: 0
value: 0
Hi there, my OpenSprinkler Pi kit just arrived today. Did anyone succeed in getting it to operate on the same Pi as HASSIO?
I think it would be great if vinteo’s repository could be made to work with this most basic configuration as well!
I add this into my configuration.yaml file (just after “scene: !include scenes.yaml”):
!include switches.yaml
This the content of the switches.yaml file
switches:
sprinkler_front_s1:
value_template: "{{ is_state('binary_sensor.sprinkler_front_s1_station_running', 'on') }}"
turn_on:
service: opensprinkler.run
data_template:
entity_id: binary_sensor.sprinkler_front_s1_station_running
# Run seconds uses the input_number below.
run_seconds: "{{ ((states('input_number.sprinkler_front_s1_station_minutes') | float) * 60) | int }}"
turn_off:
sprinkler_front_s2:
value_template: "{{ is_state('binary_sensor.sprinkler_front_s2_station_running', 'on') }}"
turn_on:
data_template:
entity_id: binary_sensor.sprinkler_front_s2_station_running
run_seconds: "{{ ((states('input_number.sprinkler_front_s2_station_minutes') | float) * 60) | int }}"
turn_off:
And I put this into my configuration.yaml:
input_number:
sprinkler_front_s1_station_minutes:
initial: 10
min: 10
max: 60
step: 10
sprinkler_front_s2_station_minutes:
initial: 10
min: 10
max: 60
step: 10
And then I created an entities card with the following entries in the code editor (on entities):
entities:
- entity: switch.sprinkler_front_s1
secondary_info: last-changed
- entity: input_number.sprinkler_front_s1_station_minutes
- entity: sensor.sprinkler_front_s1_station_status
type: entities
show_header_toggle: false
title: Front Sprinkler 1
