I have pushed an update, you will need to remove all the previous hass_opensprinkler.py files from the custom_components folder and just add the new hass_opensprinkler folder there.
Let me know if there are any issues. Sorry it took so long but I was on holiday and while I was away the sd card for my raspberrypi died so I had to get a new one and set up home assistant again
Hi @sgruby, thanks for the suggestion, I have added the support for custom updater, please upgrade to the latest versions of both custom_updater and hass_opensprinkler and check the README for the config example.
Hey. Had the same trouble with inputs.
Had to create them manually.
No docker here however.
Otherwise ok, thanks for the component.
I have to understand now why scenes do not work (the rest yes)
I am in the process of connecting my new opensprinkler in my greenhouse. I already have a few miflora sensors and have used them with miflora daemon on a raspberry pi zero for a year or two. I would also like to start irrigation on a few of the plants based on humidity values from miflora sensors. They are updating every 5 min with mqtt to home assistant.
Do you think something like this may work? Any pitfalls? have only done a dry run, and it seems to work as expected.
I finally got it working ⦠well kindaā¦
Sensor Work fine. However, when I try using the which, I have the following error.
Do any you encounter this when setting it up ?
In the frontend
In the log
2019-06-27 21:50:23 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1852492976] 'NoneType' object has no attribute 'state'
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 121, in handle_call_service
connection.context(msg))
File "/usr/src/homeassistant/homeassistant/core.py", line 1150, in async_call
self._execute_service(handler, service_call))
File "/usr/src/homeassistant/homeassistant/core.py", line 1172, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 194, in handle_service
required_features
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 316, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 337, in _handle_service_platform_call
await getattr(entity, func)(**data)
File "/config/custom_components/hass_opensprinkler/switch.py", line 47, in turn_on
self._station.turn_on(int(float(mins.state)))
I still havenāt figured out how to fix this, but you can manually create the input_numbers to get around this. Add something like this to your config:
@Vincent - The sensor, switch and binary_sensor are not in the states page. I am not sure when they disappeared, I am on 0.95.4. I saw there was a change on the opensprinkler GitHub and I downloaded the branch, put that in the custom_components folder. My configuration.yaml has not change for the login.
Hi @vinteo,
I have been using successfully your component for the last few month.
Great work by the way !
Looking at the log doing some long time due maintenance, I have seen a lot of error generated by the integration. In a day, I can actually have thousandth of line of log generated by the integration.
Do you have the same behaviour on your end ? What would be the most probable cause ?
My open sprinkler is on a rasberry Pie, do you have the same setup ?
It looks like connection issues, I donāt have the same logs, definitely not in the thousands. My setup is hass.io on a raspberry pi3. I would try check the WiiFi connection on the OpenSprinkler, does it have a strong signal and no dropouts? Since it mostly looks like its timing out trying to connect to the opensprinkler API
Having said that I think the error handling on the API requests on my component is not working as well as it should, so it doesnāt handle errors well. If everything is working there should not be any issues but when there are errors it may give the wrong error etc.
