Integrated MQTT-SN Gateway
Are there any plans to integrate support for MQTT-SN in Home Assistant. It would be nice to be able to be able to easily integrate sensors that are put to sleep for extended periods or have the ability to wake on hardware interrupt. Many low-powered battery operated wireless sensors could then be easily added to Home Assistant in a set it and forget it fashion.
Chnging from Mosquito to Paho for the MQTT add-on would do the trick but as these sensors are usually bluetooth LE, Zigbee or Z-wave a seperate radio is often requied.
