I wish there was a built-in XML parser to access and manipulate XML within Home Assistant. I ended up using GREP to parse the XML output of an external REST command, but it’s not really convenient or pretty.
Reply if you have ideas… I would prefer not using external third-party applications as I use HASSio (unless through an add-on I guess).
Thanks!
