So I have a bunch of tmeplate senors defined in my configuration.yaml and now wanted to define a filter. I looked up the documentation of the filter Integration, copy-pasted a filter definition to the end of my config file and adapted it to my needs.
Even though no error message is displayed in the YAML editor, after reloading the YAML configs, not only does the filter not work (no new entitiy shows up) but also all the sensor I had working before now show up as “unavailable”.
This is my full config file after adding the snipplet:
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
template:
- sensor:
- name: "Technical & Garden | Power"
unique_id: technical_garden_power
unit_of_measurement: W
icon: mdi:lightning-bolt
availability: >-
{{ has_value('sensor.shellyproem50_08f9e0e5c190_em0_power') and
has_value('sensor.shellyproem50_08f9e0e5c190_em1_power') }}
state: >-
{{ (states('sensor.shellyproem50_08f9e0e5c190_em0_power') | float(0) -
states('sensor.shellyproem50_08f9e0e5c190_em1_power') | float(0) ) | round(1) }}
- name: "Pellet heating status"
unique_id: pellet_heating_status
availability: "{{ has_value('sensor.shellypro4pm_08f9e0e9ed64_switch_2_power') }}"
state: >-
{% set power = states('sensor.shellypro4pm_08f9e0e9ed64_switch_2_power') | float(0) %}
{% if power < 3 %}
off
{% elif power < 20 %}
stand by
{% elif power < 140 %}
circulating
{% elif power < 270 %}
heating
{% elif power > 270 %}
ignition
{% endif %}
- name: "Electric boiler status"
unique_id: electric_boiler_status
availability: >-
{{ has_value('sensor.shellypro4pm_08f9e0e9ed64_switch_3_power') and
has_value('switch.shellypro4pm_08f9e0e9ed64_switch_3') }}
state: >-
{{ 'off' if is_state('switch.shellypro4pm_08f9e0e9ed64_switch_3', 'off')
else 'standby' if states('sensor.shellypro4pm_08f9e0e9ed64_switch_3_power')|int(0) < 20
else 'heating' }}
- name: "Wind Direction TXT"
unique_id: wind_direction_txt
availability: "{{ has_value('sensor.ecowitt_wind_direction') }}"
state: >-
{% set dir = states('sensor.ecowitt_wind_direction') | int(0) %}
{% set navDir = [ 'N', 'NNE', 'NE', 'ENE', 'E', 'ESE', 'SE', 'SSE', 'S', 'SSW', 'SW', 'WSW', 'W', 'WNW', 'NW', 'NNW', 'N' ] %}
{{ navDir[ (dir/22.5) | int(0) ] }
- platform: filter
name: "filtered heating power"
entity_id: sensor.shellypro4pm_08f9e0e9ed64_switch_2_power
filters:
- filter: time_simple_moving_average
window_size: "00:05"
precision: 2
Also in notifications I get a Log message saying:
Logger: homeassistant.config
Source: config.py:592
First occurred: October 29, 2024 at 01:43:04 (13 occurrences)
Last logged: 15:27:43
* Invalid config for 'template' at configuration.yaml, line 55: invalid template (TemplateSyntaxError: unexpected '}') for dictionary value 'sensor->3->state', got "{% set dir = states('sensor.ecowitt_wind_direction') | int(0) %} {% set navDir = [ 'N', 'NNE', 'NE', 'ENE', 'E', 'ESE', 'SE', 'SSE', 'S', 'SSW', 'SW', 'WSW', 'W', 'WNW', 'NW', 'NNW', 'N' ] %} {{ navDir[ (dir/22.5) | int(0) ] }"
* Invalid config for 'template' at configuration.yaml, line 60: 'platform' is an invalid option for 'template', check: sensor->4->platform Invalid config for 'template' at configuration.yaml, line 60: required key 'state' not provided Invalid config for 'template' at configuration.yaml, line 62: 'entity_id' is an invalid option for 'template', check: sensor->4->entity_id Invalid config for 'template' at configuration.yaml, line 64: 'filters' is an invalid option for 'template', check: sensor->4->filters
* Invalid config for 'template' at configuration.yaml, line 64: invalid template (TemplateSyntaxError: unexpected '}') for dictionary value 'sensor->3->state', got "{% set dir = states('sensor.ecowitt_wind_direction') | int(0) %} {% set navDir = [ 'N', 'NNE', 'NE', 'ENE', 'E', 'ESE', 'SE', 'SSE', 'S', 'SSW', 'SW', 'WSW', 'W', 'WNW', 'NW', 'NNW', 'N' ] %} {{ navDir[ (dir/22.5) | int(0) ] }"
What a I doning wrong here?
Thank you all in advance!
