Integrating a motion, temperature & humidity sensor in ZHA model NAS-PD07 manufactured by NEO
Hi all,
I’m new in this community. so sorry about any stupid question :slight_smile:
I want to integrate a motion sensor manufactured by NEO in ZHA.
Here is the description : Neo Motion, Temperature & Humidity Sensor (NAS-PD07) Zigbee compatibility
When I try to integrate it with ZHA, there is no entity found.
I tried the quirks (Tuya/ts0601_motion.py : zha-device-handlers/ts0601_motion.py at 5228c54d70d5eee0be09ff6ca2eeb81a538eefa1 · zigpy/zha-device-handlers · GitHub ==> but nothing.
I modified the ts0601_motion.py file adding a new class NeoMotion with the right signature and import the clusters to use (inspired by ts0601_trv.py) found in the same repo.
I have the motion sensor entity but didn’t work (always clear)
Here is the zigbee signature :
  "node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4098, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
  "endpoints": {
    "1": {
      "profile_id": 260,
      "device_type": "0x0051",
      "in_clusters": [
        "0x0000",
        "0x0004",
        "0x0005",
        "0xef00"
      "out_clusters": [
        "0x000a",
        "0x0019"
  "manufacturer": "_TZE200_7hfcudw5",
  "model": "TS0601",
  "class": "zigpy.device.Device"
and here is my ts0601_motion.py modified :
"""BlitzWolf IS-3/Tuya motion rechargeable occupancy sensor."""
from typing import Optional, Tuple, Union
from zigpy.profiles import zha
from zigpy.quirks import CustomDevice
import zigpy.types as t
from zigpy.zcl import foundation
from zigpy.zcl.clusters.general import Basic, Identify, Ota
from zigpy.zcl.clusters.security import IasZone
from zhaquirks import Bus, LocalDataCluster, MotionOnEvent
from zhaquirks.const import (
    DEVICE_TYPE,
    ENDPOINTS,
    INPUT_CLUSTERS,
    MODELS_INFO,
    OUTPUT_CLUSTERS,
    PROFILE_ID,
from zhaquirks.tuya import (
    TuyaManufClusterAttributes,
    TuyaPowerConfigurationCluster,
    TuyaUserInterfaceCluster,
from zigpy.zcl.clusters.general import (
    AnalogOutput,
    Basic,
    Groups,
    Identify,
    OnOff,
    Ota,
    Scenes,
    Time,
ZONE_TYPE = 0x0001
class MotionCluster(LocalDataCluster, MotionOnEvent):
    """Tuya Motion Sensor."""
    _CONSTANT_ATTRIBUTES = {ZONE_TYPE: IasZone.ZoneType.Motion_Sensor}
    reset_s = 15
class TuyaManufacturerClusterMotion(TuyaManufClusterAttributes):
    """Manufacturer Specific Cluster of the Motion device."""
    def handle_cluster_request(
        self,
        hdr: foundation.ZCLHeader,
        args: Tuple[TuyaManufClusterAttributes.Command],
        dst_addressing: Optional[
            Union[t.Addressing.Group, t.Addressing.IEEE, t.Addressing.NWK]
        ] = None,
    ) -> None:
        """Handle cluster request."""
        tuya_cmd = args[0]
        if hdr.command_id == 0x0001 and tuya_cmd.command_id == 1027:
            self.endpoint.device.motion_bus.listener_event(MOTION_EVENT)
class TuyaMotion(CustomDevice):
    """BW-IS3 occupancy sensor."""
    def __init__(self, *args, **kwargs):
        """Init device."""
        self.motion_bus = Bus()
        super().__init__(*args, **kwargs)
    signature = {
        #  endpoint=1 profile=260 device_type=0 device_version=0 input_clusters=[0, 3]
        #  output_clusters=[3, 25]>
        MODELS_INFO: [
                    ("_TYST11_i5j6ifxj", "5j6ifxj"),
                    ("_TYST11_7hfcudw5", "hfcudw5"),
        ENDPOINTS: {
            1: {
                PROFILE_ID: zha.PROFILE_ID,
                DEVICE_TYPE: zha.DeviceType.ON_OFF_SWITCH,
                INPUT_CLUSTERS: [Basic.cluster_id, Identify.cluster_id],
                OUTPUT_CLUSTERS: [Identify.cluster_id, Ota.cluster_id],
    replacement = {
        ENDPOINTS: {
            1: {
                DEVICE_TYPE: zha.DeviceType.OCCUPANCY_SENSOR,
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    MotionCluster,
                    TuyaManufacturerClusterMotion,
class NeoMotion(CustomDevice):
    """NAS-PD07 occupancy sensor."""
        """Init device."""
    signature = {
        #  endpoint=1 profile=260 device_type=81 device_version=0 input_clusters=[0, 4, 5, 61184]
        #  output_clusters=[10, 25]>
        MODELS_INFO: [
                    ("_TZE200_7hfcudw5", "TS0601"),
        ENDPOINTS: {
            1: {
                DEVICE_TYPE: zha.DeviceType.SMART_PLUG,
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
                    TuyaManufClusterAttributes.cluster_id,
                OUTPUT_CLUSTERS: [Time.cluster_id, Ota.cluster_id],
    replacement = {
        ENDPOINTS: {
            1: {
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
                    MotionCluster,
Thank you for your help :pray:
im having the same issue, i ahve created a new device support at Zigbee2MQTT
hey man, any luck on this? have you found a way??
I bought the same sensor. after I added to ZHA i found:
The “quirk” it uses from ZHA Device Handlers (a.k.a. zha-quirks) may need to be modified, post issue :
https://github.com/zigpy/zha-device-handlers/issues
If there is not already an existing request for it then submit a new “Device support request” for it there.
Be sure to fill provide all the information requested as well as additional info or links about the device.
Reason why this is so is here in ZHA docs:
https://www.home-assistant.io/integrations/zha#zha-exception-and-deviation-handling
Hey guys,
I’d like to buy one of these as it seems it’s the only one on the market that has motion, temp, and humidity all in one? Please advise if there are alternatives
Has this now been integrated properly in z2m?
How do you guys like the sensor?
