Integrating Fibaro Z-Wave HC2 into Home Assistant
Hi all,
I really love the HomeAssistant interface and currently all my Z-Wave motion sensors, Dimmer 2 modules and Relays are all added into my Fibaro HC2 controller.
Can someone point me in the right direction for integrating all my Z-Wave devices into Home Assistant?
I noticed that Vera and Wink Hubs were mentioned on the Z-Wave component pages, but it did not mention Fibaro HC2 controller
Many thanks,
litfoo
Hi @litfoo,
Did you made any progress yet integrating your Fibaro HC2 with Home Assistant? My situation is like yours. I started integrating some HC2 scenes which I use often by adding them in Home Assistant as command_line switches (curl requests to HC2 API) but this doesn’t feel like the right way to go so I’m open for new ideas and suggestions on integrating the two.
Sorry for such late reply and I’m sure you have managed to find a solution
there is now an official Fibaro component here https://www.home-assistant.io/components/fibaro/
I myself have added my HC2 controller and can see all my Z-Wave devices. Am having some issues with incorrect states being displayed for my light status at the moment
How did you get along? All working now?
