Hello to the entire community,
I’m reaching out to you after trying countless approaches without success, hoping someone with more experience can lend me a hand.
My goal is to integrate my Huawei charging station into Home Assistant to be able to see the charging power, the energy delivered to the car, the charging status, and ideally, to control it remotely…
Here is a precise overview of my situation:
Solar System: I have already successfully integrated my Huawei inverter and battery using the custom “Huawei Solar” integration. It communicates via Modbus TCP and everything works perfectly: I can see production, consumption, battery status, etc. The charger, however, is not detected as a device within this integration.
Charger: It is the 22 kW Huawei Smart Charger model. From what I’ve been able to see, the installed firmware version should be V100R023C10SPC120.
Connection: The charger is not physically connected to the inverter but is a standalone network device. It is stably connected to my LAN via an Ethernet cable (RJ45) and has its own static IP address that responds correctly to pings. To function, it needs to see the inverter’s data via Modbus TCP; in fact, in its configuration screen, it recognizes the inverter as an “electric meter” from which it presumably gets the consumption and production data.
The Problem:
I am unable to “see” and control the charger from Home Assistant in any way. The main integration does not detect it automatically.
My question is:
Has anyone managed to integrate this specific standalone charger model? Is there an integration (perhaps in HACS) that I haven’t found?
Can the charger send its data via Modbus TCP? If so, can I use the generic Modbus integration in Home Assistant?
In the latter case, if someone had a working YAML configuration and would be kind enough to share it, I would be immensely grateful.
