Integrating Ring Alarm system with Home Assistant v. 2024.9.3
Is there a way to connect the Ring Alarm system to Home Assistant? I went to Settings > Devices & services > Integration > Add Integration. Under brand, I picked Ring.
When I try to Sign-in with Ring account, it Produces error “Invalid authentication”, without asking for an authentication code!
How can I get Home assistant to see the ring components? How can I solve this?
I’m having the same issue did something get broken with this update?
I have reported this to the GitHub tracker
@spydazcomputers - Do you need to use the Mosquito Broker MQTT, for the Home Assistant to communicate with Ring alarm system?
And I don’t know if not having Mosquito Broker MQTT is causing the authentication code NOT to be displayed?
