I’m seeking assistance with integrating a Sonoff relay (or similar) into my Laskomex LM-8 W-7 intercom system to enable remote door lock control.
Setup Details:
Blue and White wires are the wires that coming to my apartment
Green, white and red are the headset wires.
- Intercom Model: Laskomex LM-8 W-7
- Relay Model: Sonoff SV (or alternative options)
- Power Supply: The intercom system provides 6V DC. However, I’m considering using a relay that can be powered via USB, DC, or AC to ensure a stable Wi-Fi connection.
Current Wiring:
- The intercom has two wires labeled L+ and L- for power supply.
- The Sonoff SV operates on 5-24V DC.
Objective:
Integrate the Sonoff SV relay to remotely control the door lock. When the relay is OFF, the system functions normally. When the relay is ON, dialing or pressing the apartment number (e.g., 45) on the intercom downstairs should automatically unlock the door.
Challenges:
- Determining the correct wiring configuration between the Sonoff SV and the apartment intercom’s control terminals.
- Ensuring compatibility between the Sonoff SV’s voltage requirements and the intercom’s power supply.
Request:
I would appreciate guidance on:
- Proper wiring connections between the Sonoff SV and the intercom system.
- Ensuring safe and effective operation without damaging the intercom.
Can I connect the two wires coming to my apartment directly to the Sonoff relay and then add two additional wires to connect to L+ and L-? Will this configuration work, or is there a better approach?
Additionally, I’m not comfortable with soldering or modifying the relay as shown in some tutorials. Are there any “ready-to-install” relay modules available that require minimal setup, where I can simply connect the wires and have everything configured?
Thank you for your assistance.
