I am trying to find the path to the third party integration configurations. In particular I would like to find the file that stores the configuration for “My OpenGarage”. Can anyone point me into the correct direction?
The files are hidden, to stop you messing with them. Those files aren’t validated by HA - if you edit them and make a mistake HA won’t start.
I know that messing with config can cause issues…
Same warning, you can screw your home assistant if you do a mistake. But if you are up to it, they are under .storage folder as config_entries.yaml
Thank you.
