stephang
(Stephan Gumpert)
April 16, 2023, 12:41am
1
I think recently I got prompted to remove an integration as it was not needed. (distant memory)
Now every time I start up home assistant I get these error messages.
Is there a config file or something I need to edit to remove something to get rid of this error?
tom_l
April 16, 2023, 2:35am
2
Remove reolink_rest:
from configuration.yaml and restart.
stephang
(Stephan Gumpert)
April 16, 2023, 3:06am
3
@tom_l I looked in my configuration.yaml file, and nothing like that is in there. Would it be elsewhere?
tom_l
April 16, 2023, 4:16am
4
If you use VSCode you can search your entire config directory.
Otherwise, Settings → Devices & Services?
stephang
(Stephan Gumpert)
April 16, 2023, 4:32am
5
I removed the REOLINK DISCOVERY HACS addon and the error went away - when I did a search as suggested the author with reolink_rest was referenced. Thanks for your help.
