Hey Folks,
I have a really annoying problem and I don’t know if this is the right category, so if not let me know :-).
I had the custom Integration for Miele products.. It ran fine until it stops to do so. So I uninstalled it and tried to reinstall it. But i ran into a problem and unfortuately it’s not possible for me to install the custom integration anymore. I always get this error:
So first thing I did of course was to contact the custom Integration owner as I thoght it has to be a bug. But trobleshooting led to no solution, it seems to be no custom Integration related bug.
Bug-Ticket is here.
Error Details
Logger: homeassistant.util.package
Source: util/package.py:122
First occurred: 12:38:38 PM (3 occurrences)
Last logged: 12:38:41 PM
Unable to install package flatdict==4.0.1: error: subprocess-exited-with-error × python setup.py egg_info did not run successfully. │ exit code: 1 ╰─> [11 lines of output] Traceback (most recent call last): File “”, line 2, in File “”, line 14, in File “/usr/local/lib/python3.12/site-packages/setuptools/init.py”, line 16, in import setuptools.version File “/usr/local/lib/python3.12/site-packages/setuptools/version.py”, line 1, in import pkg_resources File “/usr/local/lib/python3.12/site-packages/pkg_resources/init.py”, line 2191, in register_finder(pkgutil.ImpImporter, find_on_path) ^^^^^^^^^^^^^^^^^^^ AttributeError: module ‘pkgutil’ has no attribute ‘ImpImporter’. Did you mean: ‘zipimporter’? [end of output] note: This error originates from a subprocess, and is likely not a problem with pip. error: metadata-generation-failed × Encountered error while generating package metadata. ╰─> See above for output. note: This is an issue with the package mentioned above, not pip. hint: See above for details.
Log Details
Logger: aiohttp.server
Source: /usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py:421
First occurred: 12:38:41 PM (1 occurrences)
Error handling request
File “/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py”, line 452, in _handle_request
resp = await request_handler(request)
File “/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py”, line 543, in _handle
resp = await handler(request)
File “/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py”, line 114, in impl
return await handler(request)
File “/usr/src/homeassistant/homeassistant/components/http/security_filter.py”, line 91, in security_filter_middleware
File “/usr/src/homeassistant/homeassistant/components/http/forwarded.py”, line 227, in forwarded_middleware
File “/usr/src/homeassistant/homeassistant/components/http/request_context.py”, line 28, in request_context_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 80, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 235, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/headers.py”, line 31, in headers_middleware
response = await handler(request)
File “/usr/src/homeassistant/homeassistant/components/http/view.py”, line 149, in handle
result = await handler(request, **request.match_info)
File “/usr/src/homeassistant/homeassistant/components/http/decorators.py”, line 72, in with_admin
return await func(self, request, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/components/config/config_entries.py”, line 153, in post
return await super().post(request)
File “/usr/src/homeassistant/homeassistant/components/http/data_validator.py”, line 72, in wrapper
result = await method(view, request, data, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py”, line 71, in post
result = await self._flow_mgr.async_init(
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 947, in async_init
flow, result = await task
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 965, in _async_init
flow = await self.async_create_flow(handler, context=context, data=data)
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 1076, in async_create_flow
handler = await _async_get_flow_handler(
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 2294, in _async_get_flow_handler
await _load_integration(hass, domain, hass_config)
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 2270, in _load_integration
await async_process_deps_reqs(hass, hass_config, integration)
File “/usr/src/homeassistant/homeassistant/setup.py”, line 467, in async_process_deps_reqs
await requirements.async_get_integration_with_requirements(
File “/usr/src/homeassistant/homeassistant/requirements.py”, line 52, in async_get_integration_with_requirements
return await manager.async_get_integration_with_requirements(domain)
File “/usr/src/homeassistant/homeassistant/requirements.py”, line 175, in async_get_integration_with_requirements
await self._async_process_integration(integration, done)
File “/usr/src/homeassistant/homeassistant/requirements.py”, line 190, in _async_process_integration
await self.async_process_requirements(
File “/usr/src/homeassistant/homeassistant/requirements.py”, line 255, in async_process_requirements
await self._async_process_requirements(name, missing)
File “/usr/src/homeassistant/homeassistant/requirements.py”, line 293, in _async_process_requirements
raise RequirementsNotFound(name, list(failures))
homeassistant.requirements.RequirementsNotFound: Requirements for miele not found: [‘flatdict==4.0.1’].
So what you can read in the ticket, is that I already tried to set up a new instance of HA and the problem is not existent there, Integration could be installed and runs smoothly.
Ich bin nun etwas verzweifelt und habe angst meine komplette Installation neu aufsetzen zu müssen, denn die ist mittlerweile sehr umfangreich. Könnt ihr mir vielleicht einen Tip geben wie ich das Problem eingrenzen oder sogar lösen könnte?
My Prod System overview
| Version | core-2024.2.2 |
| Installation Type | Home Assistant OS |
| Development | false |
| Supervisor | true |
| Docker | true |
| User | root |
| Virtual Environment | false |
| Python Version | 3.12.1 |
| Operating System Family | Linux |
| Operating System Version | 6.1.74-haos |
| CPU Architecture | x86_64 |
| Timezone | Europe/Berlin |
| Configuration Directory | /config |
Home Assistant Community Store
| GitHub API | ok |
| GitHub Content | ok |
| GitHub Web | ok |
| GitHub API Calls Remaining | 5000 |
| Installed Version | 1.34.0 |
| Stage | running |
| Available Repositories | 1405 |
| Downloaded Repositories | 50 |
| HACS Data | ok |
Home Assistant Cloud
| Logged In | true |
| Subscription Expiration | August 11, 2024 at 2:00 AM |
| Relayer Connected | true |
| Relayer Region | eu-central-1 |
| Remote Enabled | true |
| Remote Connected | true |
| Alexa Enabled | true |
| Google Enabled | true |
| Remote Server | eu-central-1-0.ui.nabu.casa |
| Certificate Status | ready |
| Instance ID | 0056dc4b97104c279a644e98985c9775 |
| Reach Certificate Server | ok |
| Reach Authentication Server | ok |
| Reach Home Assistant Cloud | ok |
Home Assistant Supervisor
| Host Operating System | Home Assistant OS 11.5 |
| Update Channel | stable |
| Supervisor Version | supervisor-2024.02.0 |
| Agent Version | 1.6.0 |
| Docker Version | 24.0.7 |
| Disk Total | 68.2 GB |
| Disk Used | 46.0 GB |
| Healthy | true |
| Supported | true |
| Board | ova |
| Supervisor API | ok |
| Version API | ok |
| Installed Add-ons | Samba share (12.3.0), Terminal & SSH (9.9.0), File editor (5.8.0), Grafana (9.1.3), Node-RED (17.0.7), Mosquitto broker (6.4.0), ESPHome (2023.12.9), Studio Code Server (5.15.0), Z-Wave JS (0.4.4), Advanced SSH & Web Terminal (17.1.0), Portainer (2.19.4), CUPS (3.0.3), Fusion (2024.2.1) |
Dashboards
| Dashboards | 3 |
| Resources | 34 |
| Views | 22 |
| Mode | storage |
Recorder
| Oldest Run Start Time | February 12, 2024 at 8:43 AM |
| Current Run Start Time | February 21, 2024 at 4:46 PM |
| Estimated Database Size (MiB) | 2826.54 MiB |
| Database Engine | sqlite |
| Database Version | 3.44.2 |
Thank you in advance!
