Hi! I’m trying to make gate from rtl-sdr to HA using this project as a base. The logic is quite simple - I’ve got cheap usb rtl-sdr dongle (about 10$), make binaries from rtl_433 and getting json with codes from output of rtl_433 process. I’ve made few async coroutines that filters blacklist actions, aggregates multiply clicks and sending result to the mqtt topics. It’s fully automatic at the moment with few rf433 switches that I have at home. So, I can bye another one cheap wall switch for approximately 4$ and by the single/double/triple/quadruple/quituple clicks got the triggers for automations directly inside HA. Quck and simple. But I have one problem: for example I have 3 button switch and I’ve got actions with the same names in Device -> Automation interface. Now I have three “single click” triggers, “three double click” triggers and so on.
That’s what I have in HA log during clicks:
2020-07-03 19:39:16 INFO (MainThread) [homeassistant.components.mqtt.discovery] Found new component: device_automation rtl433_Smoke-GS558_10807 unit_0_4546e0_single
2020-07-03 19:39:33 INFO (MainThread) [homeassistant.components.mqtt.discovery] Found new component: device_automation rtl433_Smoke-GS558_10807 unit_0_4546e0_double
2020-07-03 19:39:46 INFO (MainThread) [homeassistant.components.mqtt.discovery] Found new component: device_automation rtl433_Smoke-GS558_10807 unit_0_4546e0_triple
2020-07-03 19:39:49 INFO (MainThread) [homeassistant.components.mqtt.discovery] Found new component: device_automation rtl433_Smoke-GS558_10807 unit_0_4546e0_quadruple
2020-07-03 19:39:53 INFO (MainThread) [homeassistant.components.mqtt.discovery] Found new component: device_automation rtl433_Smoke-GS558_10807 unit_0_4546e0_many
2020-07-03 19:39:58 INFO (MainThread) [homeassistant.components.mqtt.discovery] Found new component: device_automation rtl433_Smoke-GS558_10807 unit_0_2546e0_single
2020-07-03 19:40:00 INFO (MainThread) [homeassistant.components.mqtt.discovery] Found new component: device_automation rtl433_Smoke-GS558_10807 unit_0_2546e0_double
2020-07-03 19:40:03 INFO (MainThread) [homeassistant.components.mqtt.discovery] Found new component: device_automation rtl433_Smoke-GS558_10807 unit_0_2546e0_triple
2020-07-03 19:40:06 INFO (MainThread) [homeassistant.components.mqtt.discovery] Found new component: device_automation rtl433_Smoke-GS558_10807 unit_0_2546e0_quadruple
I want actions will named like “unit_0_4546e0_single” but not just “single click”
And that’s what I see in HA device automations:
The example of json topic/message for button is:
homeassistant/device_automation/rtl433_Smoke-GS558_10807/action_unit_0_4546e0_double/config
"automation_type": "trigger","type": "click",
"subtype": "double", "payload": "2","topic": "/rtl433/Smoke-GS558/10807/unit_0_4546e0",
"device": {
"identifiers": ["rtl433_Smoke-GS558_10807"],
"name": "Smoke-GS558_10807", "model": "Smoke-GS558"
Tell me please what I’m doing wrong?
