is there any integration for the Klarstein DryFy dehumidifiers available?
I think it would be very interesting to have such an integration, because there is no integration for dehumidifiers at all (excluding Midea Inventor Dehumidifier this one, because it’s not available any more). So it would be great if somebody can help me.
Thank you,
Alex
This integration will be grate also for me
i’m very interested on this. First step i think is get protocol, how we can proceed? i have a tcpdump but seems to be encripted or very difficult to understand…
edit: another info, this seems a nodemcu unit, can be decripted in some way?
It is Tuya compatible, everything but lights works from Tuya app. Maybe it will work with scenes.
En la integración directa de tuya no la agrega como dispositivo
Tutorial for Klarstein Wonderwall IR Heater
Phone:
- Install TuyaSmart and complete registration / configuration
- Set Klarstein Wonderwall in Pairing mode
- Add new device from Small Appliances > Heater (Wifi)
- Set WIFI SSID and password
- Check that you can control Wonderwall with Tuya app
(pic just for preview)
Home Assistant:
- Configuration > Integration > Add > Tuya* and complete configuration
*Google tutorial if you’re not sure how to do it
After all the steps are successful you should have new entity Climate device and Entity
Dashboard:
- Add card > Generic Thermostat > climate.2387420375203
Pros:
- can control heater from HA
- can set schedule or automation when heater is on/off from HA
- possible to set temperature with the new tuya cloud integration
Cons:
- cannot turn the heater off, but it’s possible to set temp to 0 so it doesnt heat
its possible to set temperature with the new tuya cloud integration
Hello all,
I only have one entity as bellow:
How can i get all the information on HA as tuya cloud and app:
Hey, it’s been a while but, if anyone else need this,
here’s how to add the dryfy connect information you see in smartlife to HA:
Install the Hacs integration localtuya (GitHub - rospogrigio/localtuya: local handling for Tuya devices )
Read the repo, but after the integration is all setup, you can add a device(dryfy connect) and manually add the sensor(one by one, and it s a bit a pain in the a** to know which value is but, doable) from tuya iot.
It gives this on mine:
I keept the entity from the HA tuya integration, since i can put it in a “type: humidifier” card, and control the humidity target %, because via locatuya, there’s the value for humidity target but i did not succed to make it work, but with normal HA tuya it work so^^
@Asteroidz : Hi, I have managed to integrate my DryFy using the integration, but all I can do is switch it on and off. I have no clue which sensor(s) to configure and which values to use.
Is there a way you can post what you have used?
Many thanks in advance!
Regards,
Joop
It took me several days to find out how this works, but finally managed to get it configured:
If anyone needs details of each sensor/DP let me know
If you could provide it to me, it would be great!
I don’t see another way then posting a screenshot of each entity. There are 2 other values: 102, which is a Switch (Water Pump) and 11 which I have no idea what it stands for.
Hope it helps. But first the view in HA:
Thanks, however i do not get the point on how and where to configure the entity ? in localtuya ? as i use the regular tuya integration (but with missing data).
Can you probably share the yaml code ?
Hi, I don‘t know where to find the YAML code (I am not very experienced), anyhow here is what I have:
You click on „Configure“ and then you either add or edit an existing device:
Then at the bottom you click „Add more entities“ an you select the entities by number and configure them as in my screenshots
Hope this helps.
Thank you very much, that really helped me.
FYI, 11 is ‘Fault’ (a number?) and 102 is the pump switch.
@Roger954 Thanks for the „Fault“ Info. Next time my water container is full I will check if it has a value other then 0
Hello! Can’t seem to make the countdown work, not sure I filled the config correctly? I get the slider in Home Assistant but it doesn’t update the value on the device
Sorry I can‘t help you with that, I do not use that feature.
I believe that some settings can only be used when the device is on, not sure though.
Maybe you can change the countdown from slider to dropdown list somewhere?
I would like to integrate my Klarstein DryFy Connect 30 with HA, but I can’t get it connected to Tuya, so that I can get the " local_key" to be able to use it with local-tuya.
Is there some other way how can I get the local_key without connecting it to Tuya?
I have it successfully connected to Klarstein app, but in Tuya it is asking me to put it to pairing mode or reset, but I can’t find a way how do do it.
