Hi all,
I have Hassio installed from the image on a Raspberry PI3.
I have configured my duckdns in https and it works
I have a google home and a IFTTT account (it works for other triggers).
The connection IFTT and Google Assistant works fine (my command is understood and I have the vocal reply).
I’m a newbie, but I have read (all) the tutorials and followed the instructions.
https://community.home-assistant.io/t/ifttt-webhook-and-webhook-id/84670
https://community.home-assistant.io/t/how-to-integrate-google-assistant-and-home-assistant-api-using-only-ifttt/19269
and so on.
In my configuration.yaml, I added
script: !include scripts.yaml
# Example configuration.yaml entry
ifttt:
key: xxx - found on the (https://ifttt.com/maker_webhooks/settings)
In the automation.yaml, I put
- alias: automate_ifttt
- platform: event
event_type: ifttt_webhook_received
event_data:
action: 'call_service'
- service_template: '{{ trigger.event.data.service }}'
data_template:
entity_id: '{{ trigger.event.data.entity_id }}'
In my script.yaml (number was generated in the HASSIO script editor)
'1575417635560':
alias: allume_TV
sequence:
- device_id: 0622cf9141e44e14ae631fae2ec0f6c8
domain: switch
entity_id: switch.nodon_id_rf_asp_3_1_00_smart_plug_switch
type: toggle
I test my script in the HASSIO Developpement tool/Service and it trigger my switch.
In the IFTT applet, I put in the Make a web request triggered by Google Assitanst (Say a simple phrase)
URL : https://MYDNS.duckdns.org:8123/api/webhook/xxxx (found once during the IFTT integration)
Method : POST
Content : application/JSON
Body : { “action”: “call_service”, “service”: “script.toggle”, “entity_id”:“script.1575417635560” }
I think I have done everything, BUT it doesn’t work
When I talk to my Google Home Assistant or App, it replies to my command and the applet is run with no error (I can see in the activity). BUT nothing is triggered… no error but nothing is done.
Where to find the activity of the HASSIO and for instance the request coming form IFTTT ? I could see if I received something or not and dig further…
Anyone has an idea ?
