Integration in custom_components not found
Hi, I am trying to get the Sector Alarm integration to work and have copied the files to the custom_components/sector folder under config (in the Synology Docker). After restarting the HA server and trying to add the integration, Sector is not found, and the log shows the error message below. Any idea what is wrong?
2021-11-18 09:15:37 ERROR (MainThread) [pyatv.support.mdns] exception during data handling
File “/usr/local/lib/python3.9/site-packages/pyatv/support/mdns.py”, line 303, in datagram_received
delegate.datagram_received(data, addr)
File “/usr/local/lib/python3.9/site-packages/pyatv/support/mdns.py”, line 429, in datagram_received
decoded_msg = DnsMessage().unpack(data)
File “/usr/local/lib/python3.9/site-packages/pyatv/support/dns.py”, line 385, in unpack
self.resources.extend(
File “/usr/local/lib/python3.9/site-packages/pyatv/support/dns.py”, line 386, in
DnsResource.unpack_read(buffer) for _ in range((header.arcount))
File “/usr/local/lib/python3.9/site-packages/pyatv/support/dns.py”, line 338, in unpack_read
qtype, qclass, ttl, rd_length = unpack_stream(">2HIH", buffer)
File “/usr/local/lib/python3.9/site-packages/pyatv/support/dns.py”, line 22, in unpack_stream
return struct.unpack(fmt, buffer.read(size))
struct.error: unpack requires a buffer of 10 bytes
File “/usr/local/lib/python3.9/site-packages/pyatv/support/dns.py”, line 342, in unpack_read
rd = qtype.parse_rdata(buffer, rd_length)
File “/usr/local/lib/python3.9/site-packages/pyatv/support/dns.py”, line 260, in parse_rdata
return parse_txt_dict(buffer, length)
File “/usr/local/lib/python3.9/site-packages/pyatv/support/dns.py”, line 201, in parse_txt_dict
chunk = parse_string(buffer)
File “/usr/local/lib/python3.9/site-packages/pyatv/support/dns.py”, line 142, in parse_string
chunk_length = unpack_stream(">B", buffer)[0]
struct.error: unpack requires a buffer of 1 bytes
2021-11-18 09:15:50 ERROR (MainThread) [frontend.js.latest.202108090] :0:0 Script error.
