hello, I use the Homematic IP sensor HmIP-STE2-PCB, which allows “temp differences” - for now I only see the battery status - no temperatures.
THX in advance …
Uwe
THX in advance …
Uwe
Support for that device was introduced with pyhomematic 0.1.72, which has been released 18 days ago. So after the most recent release of Home Assitant. Hence you have to wait for the next release.
Hi, got the same problem, but allthough a New release came out a few days ago there is still just the battery status shown, no temperatures…
It should work I guess. But since I don’t have the device I could never test it myself. Let’s see what others have to say.
Not work till now, only the battery as described. THx.
Allthough it is an HomematicIP Cloud Device? I tried adding “TempModuleSTE2” to your mentioned list, but nothing changed.
At no point in this thread it was clarified if the HomeMatic or the Homematic IP cloud integration is being used. My statement is valid for the first option (which makes use of a CCU or Raspberrymatic). If this thread is about the cloud-integration, then ignore my statements.
Except for the topic because the device says HmIP. Don’t know if it even works in the homematic environment. Any guess for HmIP? Thanks for your help so far!!
The component is used in the Cloud environment (as specified and works fine in the homematicIP-App.
Of course, the regular HomeMatic integration supports HmIP deivces perfectly fine. That’s why I have reacted to this topic. Most of the HomeMatic users are using this integration. Only users who are using the HomeMatic IP Access Point have to use the cloud integration. But I’m not involved with that one. Hence it appears my suggestion for the fix is irrelevant in context of this thread.
Anyways thanks for your help. But then the thread should not be marked as solved so that it is up to date again, right?
That’s correct.
coreGreenberet added the device to the library 15 days ago.Does this mean, that we just have to wait until our home assistant build updates or do I have to put the new library manualy into the customcomponents folder? If so, how do I do that?
Any help would be appreciated!!
Any Ideas?
Doesnt work till now
Just checken with my CCU integration. I can only see battery status, voltage, ID, Icon, RSSID, friendly name and no temperatur in home assistant core-2021.5.4.
I also tried it with AP and there battery status only.
I would not really care which one works as the main goal was to have the temperatur on the HA status screen in the living room. I guess I have to wait for a couple of updates.
Yes, I See the battery and no temperature with homematicIP cloud …
For me it is still not working for the homematic IP cloud. Has anybody had more success? May be with the CCU?
Lars
NOPE … doesnt work.
