i`m trying to add a few led strips to my home assistant, but it seems i can not add the Flux_led integration from the gui. (configuration->integrations->+add integration)
is there something to add to get all available integrations in the gui or what did i miss?
Hi there…Its said that flux led should be available in integrations page to configure but it is missing for me too. Instead of configuring it in UI you can add something like this to your configuration.yaml and make the light work.
light:
- platform: flux_led
devices:
192.168.0.131:
mode: "rgb"
192.168.0.132:
name: Living Room LED
mode: "rgb"
please change the ip to ip of your lights and also the mode if its rgbw
cool, i got it to show up and kinda do stuff
i got the error: no unique entity id though, so it seems it misses a lot of communication and cant see if its on or off etc. so i can occasionally turn it on, or off or change the color or go to warm white… but not reliably… anything else you did to get things under control?
You can flash wled if the controller is esp. It is reliable and advanced. But unlike magichome, wled is local and so might need to open some ports or so control it from outside your network directly. Check this.
Most integrations aren’t available that way. All you have to do is follow the docs for the integration and they’ll tell you whether it supports UI setup, or YAML setup.
i tried before and after updating, its not in the ui. now im running latest version on core and supervisor. i`ll have a look at the WLED firmware. thank you.
