Integration of a Hunter fan with RFX transmitter
I am trying to integrate a Hunter fan with an USB RFX transmitter.
Hunter fan: Model
Remote: Model
RFX transmitter: RFXtrx433E with latest Ext2 Firmware
After running the RFX Manager on PC, I can detect the signals of the remote but only with the “undec on” option checked. Here’s the result.
Fan button
7/4/2024 02:59:22:451= 080301051DFEA0049B
Packettype        = UNDECODED RF Message
UNDECODED ARC:1DFEA0049B
7/4/2024 02:59:22:669= 0A03010630E3023FC40491
UNDECODED ARC:30E3023FC40491
7/4/2024 02:59:24:093= 0A03010730E3023BDC049B
UNDECODED ARC:30E3023BDC049B
7/4/2024 02:59:24:155= 080301081BFB80049B
UNDECODED ARC:1BFB80049B
7/4/2024 02:59:24:218= 0A03010930A3023FDC049B
UNDECODED ARC:30A3023FDC049B
7/4/2024 02:59:27:159= 0A03010A30E2023FDC049B
UNDECODED ARC:30E2023FDC049B
7/4/2024 02:59:27:377= 0803010B1DFEE0049B
UNDECODED ARC:1DFEE0049B
Up button
7/4/2024 02:59:55:706= 0A03010C30E2201DFE049A
UNDECODED ARC:30E2201DFE049A
7/4/2024 02:59:58:331= 0A03010D30E2201DFE0491
UNDECODED ARC:30E2201DFE0491
7/4/2024 02:59:58:549= 0A03010E30E3201DFE0491
UNDECODED ARC:30E3201DFE0491
7/4/2024 03:00:00:082= 0803010F1CDFE0049A
UNDECODED ARC:1CDFE0049A
7/4/2024 03:00:00:192= 0A03011030E3201DEE049A
UNDECODED ARC:30E3201DEE049A
7/4/2024 03:00:00:410= 0A03011130E2201DFE04A4
UNDECODED ARC:30E2201DFE04A4
Down button
7/4/2024 03:00:23:607= 0803011B19F2800493
UNDECODED ARC:19F2800493
7/4/2024 03:00:23:654= 0803011C19FE80049C
UNDECODED ARC:19FE80049C
7/4/2024 03:00:23:826= 0A03011D30E2202DFD04A5
UNDECODED ARC:30E2202DFD04A5
7/4/2024 03:00:25:141= 0A03011E30E3202DF5049B
UNDECODED ARC:30E3202DF5049B
7/4/2024 03:00:25:250= 0A03011F30A2202DF5049B
UNDECODED ARC:30A2202DF5049B
7/4/2024 03:00:25:297= 0A03012030E2202DF5049B
UNDECODED ARC:30E2202DF5049B
7/4/2024 03:00:26:673= 0A03012130E3202DED0492
UNDECODED ARC:30E3202DED0492
7/4/2024 03:00:26:891= 0A03012230E2202DED049B
UNDECODED ARC:30E2202DED049B
Is it possible to “decode” these command IDs and use them?
Unfortunately, HA doesn’t detect the device, even if I enable the automatic add.
I found this topic but didn’t find any solution to add it and find it under devices or entities.
Thanks a lot for your help!
The Hunter TX36 fan is supported by the RFXtrx433E but only in Pro2 firmware.
please see chapter 2.4 in the RFXtrx User Guide.
Oh, I didn’t see that! Thanks!
I will try and let you know.
Hi again,
I have installed the Pro2 firmware and have detected a signal two times.
First one is the same as before as I checked undec on, ARC and Lightning4.
Second time was by checking only undec on (and no protocol).
This is what i get with the fan button:
7/9/2024 06:32:01:239= 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
Packettype    = RAW Packet
Packet Length = 252
subtype       = RAW packet
Sequence nbr  = 67
Repeat        = 0
Nbr of pulses = 62
237  475  297  459  316  457  316  460  308  464  302  477  297  457  316  456  306  467  308  467  306  458  316  5015  337  845  316  849  317  849  323  851  323  852  339  838  341  852  333  855  306  852  315  850  325  847  332  834  340  832  342  849  333  849  329  859  308  848  320  845  334  839  709  460  336  852  708  477  722  458  329  859  323  832  709  460  330  853  695  477  703  470  720  459  722  460  725  464  326  831  705  479  694  470  715  458  320  849  331  853  337  842  726  474  689  475  313  852  315  859  309  851  310  860  330  836  331  849  701  475  328  852  321  855
7/9/2024 06:32:01:582= 447F014401014A035F02B401CC02C301CB02CB01D202B901DA02C901CD02C901CD02D301CA02D301D10144034E02B401E102AC01DF02BD01CC0144034D0154034D01530000
Packet Length = 68
subtype       = 2nd RAW packet
Sequence nbr  = 68
Repeat        = 1
Nbr of pulses = 16
330  863  692  460  707  459  715  466  697  474  713  461  713  461  723  458  723  465  324  846  692  481  684  479  701  460  324  845  340  845  339  0
Can I do something with that?
If I uncheck the undec on checkbox, I cannot see any signal.
And on HA, it doesn’t seem that the automatic add option is working.
One more thing: here is what I see in HA as I activate the logs of RFX and press the fan button:
2024-07-09 20:46:02.775 DEBUG (Thread-351 (_connect)) [RFXtrx] Recv: 0xfc 0x7f 0x00 0x1a 0x00 0x01 0x6b 0x01 0xc4 0x01 0x43 0x01 0xb3 0x01 0x55 0x01 0xb6 0x01 0x4e 0x01 0xb7 0x01 0x3e 0x01 0xc7 0x01 0x3c 0x01 0xc1 0x01 0x48 0x01 0xb6 0x01 0x50 0x01 0xb5 0x01 0x3d 0x01 0xc9 0x01 0x3d 0x01 0xbf 0x01 0x48 0x01 0xb6 0x01 0x4d 0x13 0x7c 0x01 0x5f 0x03 0x3e 0x01 0x51 0x03 0x3e 0x01 0x51 0x03 0x3a 0x01 0x51 0x03 0x3e 0x01 0x58 0x03 0x43 0x01 0x65 0x03 0x2c 0x01 0x74 0x03 0x31 0x01 0x6d 0x03 0x3c 0x01 0x46 0x03 0x3d 0x01 0x51 0x03 0x3f 0x01 0x4c 0x03 0x3d 0x01 0x63 0x03 0x30 0x01 0x5e 0x03 0x36 0x01 0x68 0x03 0x3a 0x01 0x5c 0x03 0x3e 0x01 0x5f 0x03 0x40 0x01 0x4f 0x03 0x40 0x01 0x47 0x03 0x3d 0x01 0x5c 0x03 0x36 0x02 0xe0 0x01 0xc2 0x01 0x56 0x03 0x3e 0x02 0xd2 0x01 0xca 0x02 0xdd 0x01 0xba 0x01 0x5d 0x03 0x3d 0x01 0x59 0x03 0x28 0x02 0xe0 0x01 0xb1 0x01 0x62 0x03 0x3b 0x02 0xca 0x01 0xc5 0x02 0xd1 0x01 0xc8 0x02 0xde 0x01 0xb7 0x02 0xde 0x01 0xb9 0x02 0xe5 0x01 0xc2 0x01 0x51 0x03 0x2f 0x02 0xd2 0x01 0xca 0x02 0xc5 0x01 0xc7 0x02 0xd6 0x01 0xbd 0x01 0x4e 0x03 0x3f 0x01 0x5e 0x03 0x35 0x01 0x73 0x03 0x32 0x02 0xdf 0x01 0xc4 0x02 0xcb 0x01 0xc3 0x01 0x49 0x03 0x3c 0x01 0x51 0x03 0x46 0x01 0x44 0x03 0x43 0x01 0x4b 0x03 0x38 0x01 0x61 0x03 0x30 0x01 0x5f 0x03 0x38 0x02 0xd3 0x01 0xc8 0x01 0x58 0x03 0x3e 0x01 0x55 0x03 0x3f
2024-07-09 20:46:02.778 DEBUG (Thread-351 (_connect)) [RFXtrx] Recv: 0x44 0x7f 0x01 0x1b 0x01 0x01 0x5f 0x03 0x3e 0x02 0xd2 0x01 0xbc 0x02 0xd0 0x01 0xbb 0x02 0xd4 0x01 0xbf 0x02 0xcf 0x01 0xc8 0x02 0xd5 0x01 0xbe 0x02 0xd9 0x01 0xba 0x02 0xe0 0x01 0xbc 0x02 0xe2 0x01 0xbc 0x01 0x54 0x03 0x3d 0x02 0xc5 0x01 0xc7 0x02 0xc9 0x01 0xc5 0x02 0xd2 0x01 0xbb 0x01 0x54 0x03 0x3f 0x01 0x66 0x03 0x30 0x01 0x69 0x00 0x00
2024-07-09 20:46:02.839 DEBUG (Thread-351 (_connect)) [RFXtrx] Recv: 0x94 0x7f 0x00 0x1c 0x01 0x00 0x4d 0x01 0xba 0x02 0xe4 0x01 0xb7 0x01 0x56 0x03 0x34 0x02 0xd3 0x01 0xc3 0x02 0xc9 0x01 0xcb 0x02 0xd0 0x01 0xbe 0x01 0x51 0x03 0x40 0x01 0x53 0x03 0x3e 0x01 0x75 0x03 0x2d 0x02 0xe7 0x01 0xc7 0x02 0xc7 0x01 0xbd 0x01 0x4e 0x03 0x3c 0x01 0x55 0x03 0x47 0x01 0x46 0x03 0x3e 0x01 0x55 0x03 0x37 0x01 0x5a 0x03 0x35 0x01 0x5e 0x03 0x3b 0x02 0xd3 0x01 0xca 0x01 0x51 0x03 0x42 0x01 0x55 0x03 0x3f 0x01 0x62 0x03 0x44 0x02 0xcd 0x01 0xbe 0x02 0xcb 0x01 0xb7 0x02 0xd2 0x01 0xcc 0x02 0xce 0x01 0xc4 0x02 0xd9 0x01 0xb7 0x02 0xe3 0x01 0xbb 0x02 0xe2 0x01 0xb3 0x02 0xeb 0x01 0xb9 0x01 0x58 0x03 0x3a 0x02 0xc5 0x01 0xc9 0x02 0xc7 0x01 0xc8 0x02 0xd7 0x01 0xb9 0x01 0x52 0x03 0x42 0x01 0x64 0x03 0x2f 0x01 0x68 0x00 0x00
2024-07-09 20:46:02.999 DEBUG (Thread-351 (_connect)) [RFXtrx] Recv: 0xfc 0x7f 0x00 0x1d 0x00 0x01 0x6e 0x01 0xbc 0x01 0x47 0x01 0xb5 0x01 0x51 0x01 0xaf 0x01 0x4e 0x01 0xba 0x01 0x3b 0x01 0xc9 0x01 0x3b 0x01 0xcb 0x01 0x41 0x01 0xb5 0x01 0x4c 0x01 0xb9 0x01 0x3d 0x01 0xc3 0x01 0x44 0x01 0xbf 0x01 0x3f 0x01 0xbb 0x01 0x4d 0x13 0x82 0x01 0x63 0x03 0x39 0x01 0x52 0x03 0x3b 0x01 0x51 0x03 0x37 0x01 0x55 0x03 0x34 0x01 0x59 0x03 0x41 0x01 0x64 0x03 0x2d 0x01 0x68 0x03 0x41 0x01 0x61 0x03 0x3f 0x01 0x4b 0x03 0x3a 0x01 0x51 0x03 0x33 0x01 0x57 0x03 0x3f 0x01 0x60 0x03 0x2c 0x01 0x65 0x03 0x2d 0x01 0x69 0x03 0x3c 0x01 0x60 0x03 0x3b 0x01 0x61 0x03 0x3f 0x01 0x44 0x03 0x40 0x01 0x51 0x03 0x37 0x01 0x60 0x03 0x2f 0x02 0xd7 0x01 0xc9 0x01 0x57 0x03 0x39 0x02 0xd0 0x01 0xc2 0x02 0xe5 0x01 0xba 0x01 0x5a 0x03 0x3e 0x01 0x5c 0x03 0x2c 0x02 0xd4 0x01 0xbc 0x01 0x5f 0x03 0x33 0x02 0xd1 0x01 0xc6 0x02 0xc7 0x01 0xc8 0x02 0xdd 0x01 0xbd 0x02 0xdb 0x01 0xb7 0x02 0xe7 0x01 0xc1 0x01 0x52 0x03 0x31 0x02 0xcd 0x01 0xc5 0x02 0xcb 0x01 0xca 0x02 0xd2 0x01 0xb9 0x01 0x5a 0x03 0x38 0x01 0x59 0x03 0x3c 0x01 0x6a 0x03 0x2f 0x02 0xe7 0x01 0xc5 0x02 0xc3 0x01 0xc5 0x01 0x51 0x03 0x3b 0x01 0x56 0x03 0x3b 0x01 0x4f 0x03 0x37 0x01 0x52 0x03 0x38 0x01 0x60 0x03 0x2f 0x01 0x60 0x03 0x36 0x02 0xd0 0x01 0xc5 0x01 0x58 0x03 0x3d 0x01 0x5f 0x03 0x3c
2024-07-09 20:46:03.003 DEBUG (Thread-351 (_connect)) [RFXtrx] Recv: 0x44 0x7f 0x01 0x1e 0x01 0x01 0x61 0x03 0x3a 0x02 0xd7 0x01 0xb9 0x02 0xd0 0x01 0xb0 0x02 0xe1 0x01 0xbe 0x02 0xd1 0x01 0xbe 0x02 0xe2 0x01 0xb7 0x02 0xdb 0x01 0xb8 0x02 0xe7 0x01 0xb7 0x02 0xe7 0x01 0xb9 0x01 0x58 0x03 0x34 0x02 0xcd 0x01 0xbe 0x02 0xcf 0x01 0xc1 0x02 0xe0 0x01 0xb4 0x01 0x52 0x03 0x3b 0x01 0x69 0x03 0x2b 0x01 0x6b 0x00 0x00
Thanks in advance!
I bought a Broadlink RM4 pro and was able to learn commands and make scripts easily with it for my Hunter fan.
If anyone is interested, let me know.
