Integration of a sensor looks odd
i measure the electric power surplus with this template code
      - name: ueberschuss
        unique_id: TEST1000
        device_class: power
        state_class: measurement
        unit_of_measurement: W
        state: >
          {% if states("sensor.tasmota_sm_16_7_0")|float > 0 %}
          0
          {% else %}
          {{ states('sensor.tasmota_sm_16_7_0') | float * (-1) }}
          {% endif %}
after this i divided it by 1000 to get the unit kW with this code
      - name: ueberschuss_kW
        state: "{{ states('sensor.ueberschuss') | float / 1000 }}"
        unique_id: TEST55
        device_class: power
        unit_of_measurement: kW
and finally i integrate the result with this code to get the energy
  - platform: integration
    source: sensor.ueberschuss_kW
    unique_id: TEST999
The results are stored i a counter of all time and for days. I thought it works but i noticed something strange yesterday.
I looked at the load curve and on the integration, a little after 9:00 the integration jumps from 0 to over 1,5 kWh from a little amount of electric power surplus.
Did i anything wrong with my sensors or is this a bug ?
Best regards
Kai
You need to use left integration method instead of the default of trapezoidal. Search the forum for lots of similar posts if you want a detailed explanation of why (combination of math and how data is stored in HA).
The above mentioned is definitely very important.
Also note that you need frequent update of the wattage sensor for this to be accurate if wattages fluctuate a lot (which they tend to do). The problem is even worse if you calculate overshoot by subtracting sensors with different update intervals/timestamps. If you can also do the calculation from kWh sensors, you should definitely go that way.
Thank you for your super fast reply’s.
I made a new sensor for the integration:
    unique_id: TEST1234
    method: left
    unit_time: h
    unit_prefix: k
    round: 2
I also have the idea to add this option
    max_sub_interval:
      seconds: 1
maybe it makes the result more accurate but it wont work.
The option “max_sub_interval” is not valid for integration.
Did you know why this is not valid ?
Best regards
Kai
