Integration of Connexoon Access in Home Assistant
Hello
I have successfully integrated Connexoon Windows, I can see all of my components and I can control them via HASS.
On the Connexoon Access application I can see my garage door and I can control it. however it does not appear in home assistant. Is this normal? Connexoon Access is not implemented in the API?
I tried to restart HASS and the connexoon bridge. I also searched the docs but I did not find any information :frowning:
Has someone already had this problem ?
i got a response from somfy spport :
Currently there are only roller shutters, screens, thermostats which can be used via the API.
