Hi, i am new to HA and have issues with integrating may Victron stuff aswell as my diybms.
both sending MQTT messages, which i can find if i listen to “#” in the MQTT broker integration.
if i add the relays like that into the configuration.yaml:
- platform: mqtt
state_topic: "diybms/output"
then the output is this:
Entity: “sensor.diybms_relay1”
State, not Attribute: “{“0”:0,“1”:0,“2”:1,“3”:1}”
if i add them like that:
- platform: mqtt
value_template: '{{ value_json.1 }}'
the state is empty.
any advice, which documents/tutorials would guide me to the right place?
Seems like there is a problem with the JSON MQTT message.
another message from the same client:
diybms/status = {“banks”:2,“cells”:4,“uptime”:151126,“commserr”:0,“sent”:78522,“received”:78518,“badcrc”:0,“ignored”:0,“oos”:2,“roundtrip”:1640}
is working!
- platform: mqtt
state_topic: "diybms/status"
value_template: '{{ value_json.roundtrip }}'
Btw the message of the first post is
diybms/output = { “0”: 0, “1”: 0, “2”: 1, “3”: 1}
tom_l
3
Try:
value_template: '{{ value_json["1"] }}'
@tom_l thanks a lot
Can you explain me the logic behind? i am curious.
tom_l
5
This '{{ value_json.1 }}' asks for the second item of the list in value_json (it starts counting from 0, so 1 is the 2nd item) , where as this '{{ value_json["1"] }}' asks for the value of the key called “1”.
