The new thermostat HmIP-eTRV-E is not yet integrated in the homematicIP Cloud integration.
It only shows the battery status but not the current temperature or the heating / valve position as for the other thermostats.
HomematicIP Cloud: Dump hap config
"3014F7110000000000000007": {
"automaticValveAdaptionNeeded": false,
"availableFirmwareVersion": "0.0.0",
"connectionType": "HMIP_RF",
"deviceArchetype": "HMIP",
"firmwareVersion": "1.0.10",
"firmwareVersionInteger": 65546,
"functionalChannels": {
"0": {
"busConfigMismatch": null,
"coProFaulty": false,
"coProRestartNeeded": false,
"coProUpdateFailure": false,
"configPending": false,
"controlsMountingOrientation": null,
"deviceCommunicationError": null,
"deviceDriveError": null,
"deviceDriveModeError": null,
"deviceId": "3014F7110000000000000007",
"deviceOperationMode": null,
"deviceOverheated": false,
"deviceOverloaded": false,
"devicePowerFailureDetected": false,
"deviceUndervoltage": false,
"displayContrast": 11,
"dutyCycle": false,
"functionalChannelType": "DEVICE_OPERATIONLOCK",
"groupIndex": 0,
"groups": [
"00000000-0000-0000-0000-000000000009"
"index": 0,
"label": "",
"lockJammed": null,
"lowBat": false,
"mountingOrientation": "LEFT",
"multicastRoutingEnabled": false,
"operationLockActive": false,
"particulateMatterSensorCommunicationError": null,
"particulateMatterSensorError": null,
"powerShortCircuit": null,
"profilePeriodLimitReached": null,
"routerModuleEnabled": false,
"routerModuleSupported": false,
"rssiDeviceValue": -47,
"rssiPeerValue": -49,
"shortCircuitDataLine": null,
"supportedOptionalFeatures": {
"IFeatureBusConfigMismatch": false,
"IFeatureDeviceCoProError": false,
"IFeatureDeviceCoProRestart": false,
"IFeatureDeviceCoProUpdate": false,
"IFeatureDeviceCommunicationError": false,
"IFeatureDeviceDriveError": false,
"IFeatureDeviceDriveModeError": false,
"IFeatureDeviceIdentify": false,
"IFeatureDeviceOverheated": false,
"IFeatureDeviceOverloaded": false,
"IFeatureDeviceParticulateMatterSensorCommunicationError": false,
"IFeatureDeviceParticulateMatterSensorError": false,
"IFeatureDevicePowerFailure": false,
"IFeatureDeviceTemperatureHumiditySensorCommunicationError": false,
"IFeatureDeviceTemperatureHumiditySensorError": false,
"IFeatureDeviceTemperatureOutOfRange": false,
"IFeatureDeviceUndervoltage": false,
"IFeatureMulticastRouter": false,
"IFeaturePowerShortCircuit": false,
"IFeatureProfilePeriodLimit": false,
"IFeatureRssiValue": true,
"IFeatureShortCircuitDataLine": false,
"IOptionalFeatureDeviceErrorLockJammed": false,
"IOptionalFeatureDeviceOperationMode": false,
"IOptionalFeatureDisplayContrast": true,
"IOptionalFeatureDutyCycle": true,
"IOptionalFeatureLowBat": true,
"IOptionalFeatureMountingOrientation": true
"temperatureHumiditySensorCommunicationError": null,
"temperatureHumiditySensorError": null,
"temperatureOutOfRange": false,
"unreach": false
"1": {
"channelRole": "HEATING_CONTROLLER",
"functionalChannelType": "HEATING_THERMOSTAT_CHANNEL",
"groupIndex": 1,
"groups": [
"00000000-0000-0000-0000-000000000010",
"00000000-0000-0000-0000-000000000011"
"index": 1,
"label": "",
"setPointTemperature": 18.0,
"temperatureOffset": 0.0,
"valveActualTemperature": 19.2,
"valvePosition": 0.8,
"valveState": "ADAPTION_DONE"
"homeId": "00000000-0000-0000-0000-000000000001",
"id": "3014F7110000000000000007",
"label": "Heizk\u00f6rperthermostat Wohnzimmer",
"lastStatusUpdate": 1664923394152,
"liveUpdateState": "LIVE_UPDATE_NOT_SUPPORTED",
"manufacturerCode": 1,
"modelId": 425,
"modelType": "HmIP-eTRV-E",
"oem": "eQ-3",
"permanentlyReachable": true,
"serializedGlobalTradeItemNumber": "3014F7110000000000000007",
"type": "HEATING_THERMOSTAT_EVO",
"updateState": "UP_TO_DATE"
Additional info:
Logger: homematicip.base.enums
Source: components/homematicip_cloud/hap.py:254
First occurred: 13. Oktober 2022 um 13:56:53 (15 occurrences)
Last logged: 08:52:01
‘INDOOR_CLIMATE’ isn’t a valid option for class ‘GroupType’
and:
Logger: homematicip.home
First occurred: 13. Oktober 2022 um 13:56:53 (21 occurrences)
There is no class for device ‘HEATING_THERMOSTAT_EVO’ yet
There is no class for group ‘INDOOR_CLIMATE’ yet
The silver Evo version seems to have a -S suffix: HmIP-eTRV-E-S
2022-11-10 19:25:52.524 DEBUG (SyncWorker_6) [pyhomematic.devicetypes.generic] HMGeneric.init: device_description: 00325D89BB6615 : {‘TYPE’: ‘HmIP-eTRV-E-S’, ‘SUBTYPE’: ‘TRV-E’, ‘ADDRESS’: ‘00325D89BB6615’, ‘RF_ADDRESS’: 5876044, ‘CHILDREN’: [‘00325D89BB6615:0’, ‘00325D89BB6615:1’, ‘00325D89BB6615:2’, ‘00325D89BB6615:3’, ‘00325D89BB6615:4’, ‘00325D89BB6615:5’, ‘00325D89BB6615:6’, ‘00325D89BB6615:7’], ‘PARENT’: ‘’, ‘PARENT_TYPE’: ‘’, ‘INDEX’: 0, ‘AES_ACTIVE’: 1, ‘PARAMSETS’: [‘MASTER’, ‘SERVICE’], ‘FIRMWARE’: ‘1.0.10’, ‘AVAILABLE_FIRMWARE’: ‘0.0.0’, ‘UPDATABLE’: True, ‘FIRMWARE_UPDATE_STATE’: ‘UP_TO_DATE’, ‘VERSION’: 1, ‘FLAGS’: 1, ‘LINK_SOURCE_ROLES’: ‘’, ‘LINK_TARGET_ROLES’: ‘’, ‘DIRECTION’: 0, ‘GROUP’: ‘’, ‘TEAM’: ‘’, ‘TEAM_TAG’: ‘’, ‘TEAM_CHANNELS’: [], ‘INTERFACE’: ‘’, ‘ROAMING’: 0, ‘RX_MODE’: 11}
2022-11-10 19:25:52.530 DEBUG (SyncWorker_6) [pyhomematic.devicetypes.generic] HMGeneric.init: device_description: 00325D89BB6615:0 : {‘TYPE’: ‘MAINTENANCE’, ‘SUBTYPE’: ‘’, ‘ADDRESS’: ‘00325D89BB6615:0’, ‘RF_ADDRESS’: 0, ‘CHILDREN’: [], ‘PARENT’: ‘00325D89BB6615’, ‘PARENT_TYPE’: ‘HmIP-eTRV-E-S’, ‘INDEX’: 0, ‘AES_ACTIVE’: 1, ‘PARAMSETS’: [‘MASTER’, ‘VALUES’, ‘SERVICE’], ‘FIRMWARE’: ‘’, ‘AVAILABLE_FIRMWARE’: ‘’, ‘UPDATABLE’: True, ‘FIRMWARE_UPDATE_STATE’: ‘’, ‘VERSION’: 1, ‘FLAGS’: 1, ‘LINK_SOURCE_ROLES’: ‘’, ‘LINK_TARGET_ROLES’: ‘’, ‘DIRECTION’: 0, ‘GROUP’: ‘’, ‘TEAM’: ‘’, ‘TEAM_TAG’: ‘’, ‘TEAM_CHANNELS’: [], ‘INTERFACE’: ‘’, ‘ROAMING’: 0, ‘RX_MODE’: 0}
2022-11-10 19:25:52.530 DEBUG (SyncWorker_6) [pyhomematic.devicetypes.generic] HMGeneric.init: device_description: 00325D89BB6615:1 : {‘TYPE’: ‘HEATING_CLIMATECONTROL_TRANSCEIVER’, ‘SUBTYPE’: ‘’, ‘ADDRESS’: ‘00325D89BB6615:1’, ‘RF_ADDRESS’: 0, ‘CHILDREN’: [], ‘PARENT’: ‘00325D89BB6615’, ‘PARENT_TYPE’: ‘HmIP-eTRV-E-S’, ‘INDEX’: 1, ‘AES_ACTIVE’: 1, ‘PARAMSETS’: [‘MASTER’, ‘VALUES’, ‘LINK’, ‘SERVICE’], ‘FIRMWARE’: ‘’, ‘AVAILABLE_FIRMWARE’: ‘’, ‘UPDATABLE’: True, ‘FIRMWARE_UPDATE_STATE’: ‘’, ‘VERSION’: 1, ‘FLAGS’: 1, ‘LINK_SOURCE_ROLES’: ‘CLIMATE_CONTROL’, ‘LINK_TARGET_ROLES’: ‘’, ‘DIRECTION’: 1, ‘GROUP’: ‘’, ‘TEAM’: ‘’, ‘TEAM_TAG’: ‘’, ‘TEAM_CHANNELS’: [], ‘INTERFACE’: ‘’, ‘ROAMING’: 0, ‘RX_MODE’: 0}
2022-11-10 19:25:52.530 DEBUG (SyncWorker_6) [pyhomematic.devicetypes.generic] HMGeneric.init: device_description: 00325D89BB6615:2 : {‘TYPE’: ‘HEATING_CLIMATECONTROL_RECEIVER’, ‘SUBTYPE’: ‘’, ‘ADDRESS’: ‘00325D89BB6615:2’, ‘RF_ADDRESS’: 0, ‘CHILDREN’: [], ‘PARENT’: ‘00325D89BB6615’, ‘PARENT_TYPE’: ‘HmIP-eTRV-E-S’, ‘INDEX’: 2, ‘AES_ACTIVE’: 1, ‘PARAMSETS’: [‘MASTER’, ‘VALUES’, ‘LINK’, ‘SERVICE’], ‘FIRMWARE’: ‘’, ‘AVAILABLE_FIRMWARE’: ‘’, ‘UPDATABLE’: True, ‘FIRMWARE_UPDATE_STATE’: ‘’, ‘VERSION’: 1, ‘FLAGS’: 1, ‘LINK_SOURCE_ROLES’: ‘’, ‘LINK_TARGET_ROLES’: ‘CLIMATE_CONTROL’, ‘DIRECTION’: 2, ‘GROUP’: ‘’, ‘TEAM’: ‘’, ‘TEAM_TAG’: ‘’, ‘TEAM_CHANNELS’: [], ‘INTERFACE’: ‘’, ‘ROAMING’: 0, ‘RX_MODE’: 0}
2022-11-10 19:25:52.530 DEBUG (SyncWorker_6) [pyhomematic.devicetypes.generic] HMGeneric.init: device_description: 00325D89BB6615:3 : {‘TYPE’: ‘HEATING_CLIMATECONTROL_CL_RECEIVER’, ‘SUBTYPE’: ‘’, ‘ADDRESS’: ‘00325D89BB6615:3’, ‘RF_ADDRESS’: 0, ‘CHILDREN’: [], ‘PARENT’: ‘00325D89BB6615’, ‘PARENT_TYPE’: ‘HmIP-eTRV-E-S’, ‘INDEX’: 3, ‘AES_ACTIVE’: 1, ‘PARAMSETS’: [‘MASTER’, ‘VALUES’, ‘LINK’, ‘SERVICE’], ‘FIRMWARE’: ‘’, ‘AVAILABLE_FIRMWARE’: ‘’, ‘UPDATABLE’: True, ‘FIRMWARE_UPDATE_STATE’: ‘’, ‘VERSION’: 1, ‘FLAGS’: 1, ‘LINK_SOURCE_ROLES’: ‘’, ‘LINK_TARGET_ROLES’: ‘CLIMATE_CONTROL_CL’, ‘DIRECTION’: 2, ‘GROUP’: ‘’, ‘TEAM’: ‘’, ‘TEAM_TAG’: ‘’, ‘TEAM_CHANNELS’: [], ‘INTERFACE’: ‘’, ‘ROAMING’: 0, ‘RX_MODE’: 0}
2022-11-10 19:25:52.530 DEBUG (SyncWorker_6) [pyhomematic.devicetypes.generic] HMGeneric.init: device_description: 00325D89BB6615:4 : {‘TYPE’: ‘HEATING_SHUTTER_CONTACT_RECEIVER’, ‘SUBTYPE’: ‘’, ‘ADDRESS’: ‘00325D89BB6615:4’, ‘RF_ADDRESS’: 0, ‘CHILDREN’: [], ‘PARENT’: ‘00325D89BB6615’, ‘PARENT_TYPE’: ‘HmIP-eTRV-E-S’, ‘INDEX’: 4, ‘AES_ACTIVE’: 1, ‘PARAMSETS’: [‘MASTER’, ‘VALUES’, ‘LINK’, ‘SERVICE’], ‘FIRMWARE’: ‘’, ‘AVAILABLE_FIRMWARE’: ‘’, ‘UPDATABLE’: True, ‘FIRMWARE_UPDATE_STATE’: ‘’, ‘VERSION’: 1, ‘FLAGS’: 1, ‘LINK_SOURCE_ROLES’: ‘’, ‘LINK_TARGET_ROLES’: ‘WINDOW_SWITCH’, ‘DIRECTION’: 2, ‘GROUP’: ‘’, ‘TEAM’: ‘’, ‘TEAM_TAG’: ‘’, ‘TEAM_CHANNELS’: [], ‘INTERFACE’: ‘’, ‘ROAMING’: 0, ‘RX_MODE’: 0}
2022-11-10 19:25:52.530 DEBUG (SyncWorker_6) [pyhomematic.devicetypes.generic] HMGeneric.init: device_description: 00325D89BB6615:5 : {‘TYPE’: ‘HEATING_ROOM_TH_TRANSCEIVER’, ‘SUBTYPE’: ‘’, ‘ADDRESS’: ‘00325D89BB6615:5’, ‘RF_ADDRESS’: 0, ‘CHILDREN’: [], ‘PARENT’: ‘00325D89BB6615’, ‘PARENT_TYPE’: ‘HmIP-eTRV-E-S’, ‘INDEX’: 5, ‘AES_ACTIVE’: 1, ‘PARAMSETS’: [‘MASTER’, ‘VALUES’, ‘LINK’, ‘SERVICE’], ‘FIRMWARE’: ‘’, ‘AVAILABLE_FIRMWARE’: ‘’, ‘UPDATABLE’: True, ‘FIRMWARE_UPDATE_STATE’: ‘’, ‘VERSION’: 1, ‘FLAGS’: 1, ‘LINK_SOURCE_ROLES’: ‘CLIMATE_CONTROL_TRV_WTH’, ‘LINK_TARGET_ROLES’: ‘’, ‘DIRECTION’: 1, ‘GROUP’: ‘’, ‘TEAM’: ‘’, ‘TEAM_TAG’: ‘’, ‘TEAM_CHANNELS’: [], ‘INTERFACE’: ‘’, ‘ROAMING’: 0, ‘RX_MODE’: 0}
2022-11-10 19:25:52.530 DEBUG (SyncWorker_6) [pyhomematic.devicetypes.generic] HMGeneric.init: device_description: 00325D89BB6615:6 : {‘TYPE’: ‘HEATING_ROOM_TH_RECEIVER’, ‘SUBTYPE’: ‘’, ‘ADDRESS’: ‘00325D89BB6615:6’, ‘RF_ADDRESS’: 0, ‘CHILDREN’: [], ‘PARENT’: ‘00325D89BB6615’, ‘PARENT_TYPE’: ‘HmIP-eTRV-E-S’, ‘INDEX’: 6, ‘AES_ACTIVE’: 1, ‘PARAMSETS’: [‘MASTER’, ‘VALUES’, ‘LINK’, ‘SERVICE’], ‘FIRMWARE’: ‘’, ‘AVAILABLE_FIRMWARE’: ‘’, ‘UPDATABLE’: True, ‘FIRMWARE_UPDATE_STATE’: ‘’, ‘VERSION’: 1, ‘FLAGS’: 1, ‘LINK_SOURCE_ROLES’: ‘’, ‘LINK_TARGET_ROLES’: ‘CLIMATE_CONTROL_WTH_TRV’, ‘DIRECTION’: 2, ‘GROUP’: ‘’, ‘TEAM’: ‘’, ‘TEAM_TAG’: ‘’, ‘TEAM_CHANNELS’: [], ‘INTERFACE’: ‘’, ‘ROAMING’: 0, ‘RX_MODE’: 0}
2022-11-10 19:25:52.530 DEBUG (SyncWorker_6) [pyhomematic.devicetypes.generic] HMGeneric.init: device_description: 00325D89BB6615:7 : {‘TYPE’: ‘HEATING_KEY_RECEIVER’, ‘SUBTYPE’: ‘’, ‘ADDRESS’: ‘00325D89BB6615:7’, ‘RF_ADDRESS’: 0, ‘CHILDREN’: [], ‘PARENT’: ‘00325D89BB6615’, ‘PARENT_TYPE’: ‘HmIP-eTRV-E-S’, ‘INDEX’: 7, ‘AES_ACTIVE’: 1, ‘PARAMSETS’: [‘MASTER’, ‘VALUES’, ‘LINK’, ‘SERVICE’], ‘FIRMWARE’: ‘’, ‘AVAILABLE_FIRMWARE’: ‘’, ‘UPDATABLE’: True, ‘FIRMWARE_UPDATE_STATE’: ‘’, ‘VERSION’: 1, ‘FLAGS’: 1, ‘LINK_SOURCE_ROLES’: ‘’, ‘LINK_TARGET_ROLES’: ‘REMOTE_CONTROL’, ‘DIRECTION’: 2, ‘GROUP’: ‘’, ‘TEAM’: ‘’, ‘TEAM_TAG’: ‘’, ‘TEAM_CHANNELS’: [], ‘INTERFACE’: ‘’, ‘ROAMING’: 0, ‘RX_MODE’: 0}
