I can’t integrate a Outdoor Plug from Ledvance (former Osram) → LEDVANCE Compact Smart+ Outdoor Plug
With the LEDVANCE app, the integration is working smoothly.
I start searching for a new device via ZHA … no reaction … no log entry … nothing.
The plug is max. 5 meters away from the TI CC2531 USB CDC stick. The stick is nearly new … so I guess the newest firmware is on it (where can I check this?).
Any help/tip/trick?
How can I test if the ZHA integration is working properly and if also ZHA is starting the pairing process?
(I already integrated 2 innr lights … that worked and the lights are still integrated)
Thank you very much in advance!
GM
