Integration of new power sensor ADE7953 with shelly 2.5
Not sure, where to post this:
The new shelly 2.5 is available
https://github.com/arendst/Sonoff-Tasmota/wiki/Shelly-2.5
It can be used as a roller shutter.
It has the integrated power sensor (ADE7953) to determine whether the motor reached the end-position and stopped.
I’m already running ESPhome firmware on it, but I am missing the power sensor.
Any idea if/when this will be integrated in ESPhome?
Until someone comes fwd and integrate it. I think the main dev won’t add them. Not even shelly 2 had the power measure sensor.
For the moment try this
https://github.com/esphome/feature-requests/issues/182
Oh I see. To bad :frowning:
But thank you for the pointer. I will give this a try.
I see this has a branch to test, I’m trying to configure one now using this do you have a config you can share for the 2.5?
I’m currently testing that branch, here’s a config for the shelly 2.5. Be aware that the webserver is enabled and I haven’t yet set the proper reporting intervals and I have to filter out readings lower than 1 W because they look like noise even if there’s nothing connected.
Have fun!
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: "SSID"
  password: "password"
# Enable logging
logger:
  level: INFO
# Enable Home Assistant API
api:
ota:
i2c:
  sda: GPIO12
  scl: GPIO14
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO13
    name: "Washing Machine Switch"
    on_press:
      then:
        - switch.toggle: washing_machine_relay
  - platform: gpio
    pin:
      number: GPIO5
    on_press:
      then:
        - switch.toggle: dryer_relay
  - platform: ntc
    sensor: laundry_resistance_sensor
    name: "Laundry Temperature"
    unit_of_measurement: "°C"
    accuracy_decimals: 1
    icon: mdi:thermometer
    calibration:
      b_constant: 3350
      reference_temperature: 25°C
      reference_resistance: 10kOhm
  - platform: adc
    pin: A0
    update_interval: 10s
  - platform: resistance
    sensor: laundry_source_sensor
    configuration: DOWNSTREAM
    resistor: 32kOhm
  - platform: ade7953
    voltage:
    current_a:
      name: "ADE7953 Current 1"
    current_b:
      name: "ADE7953 Current 2"
    active_power_a:
      name: "ADE7953 Power 1"
    active_power_b:
      name: "ADE7953 Power 2"
      filters:
      - multiply: -1.0
status_led:
  pin:
    number: GPIO0
    inverted: yes
switch:
  - platform: gpio
    name: "Washing Machine Relay"
    pin: GPIO15
    restore_mode: ALWAYS_ON
  - platform: gpio
    pin: GPIO4
web_server:
  port: 80
This is a little off topic, but are you sure about your settings for the temperature-sensor? I get crazy high temperatures with this adc-resistance and b-constant.
I think this is the correct configuration:
Could someone please try it?
Now I don’t have any shelly to try it…
substitutions:
  devicename: shelly1
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: "xx"
  password: "xxxxx"
  ap:
    ssid: "Shelly Hotspot (xxxx)"
    password: "xxxx"
web_server:
  port: 80
captive_portal:
# Enable logging
logger:
  level: INFO
api:
  password: "xxxxxx"
ota:
  password: "xxxxxx"
i2c:
  sda: GPIO12
  scl: GPIO14
  - platform: ade7953
    voltage:
    current_a:
      name: ${devicename} Current B
    current_b:
      name: ${devicename} Current A
    active_power_a:
      name: ${devicename} Active Power B
      filters:
        - multiply: -1
    active_power_b:
      name: ${devicename} Active Power A
      filters:
        - multiply: -1
    update_interval: 60s
  # NTC Temperature
  - platform: ntc
    sensor: temp_resistance_reading
    name: ${devicename} Temperature
    icon: "mdi:thermometer"
    calibration:
      b_constant: 3350
      reference_temperature: 25C
    sensor: temp_analog_reading
    resistor: 32kOhm
  - platform: adc
    pin: A0
status_led:
  pin:
    number: GPIO0
    inverted: yes
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO13
    on_press:
      then:
        - switch.toggle: shelly_relay_1
  - platform: gpio
    pin:
      number: GPIO5
    on_press:
      then:
        - switch.toggle: shelly_relay_2
switch:
  - platform: gpio
    pin: GPIO15
    icon: "mdi:electric-switch"
    restore_mode: RESTORE_DEFAULT_OFF
  - platform: gpio
    pin: GPIO4
Thank you
@anarro Just started working with my Shelly 2.5 and found this thead. Saved me a lot of work figuring things out. I loaded your code and it seems to be working. Here is a sample of the log output…
[12:20:44][D][adc:056]: ‘temp_analog_reading’: Got voltage=0.43V
[12:20:44][D][sensor:092]: ‘temp_analog_reading’: Sending state 0.43457 V with 2 decimals of accuracy
[12:20:44][D][resistance:037]: ‘temp_resistance_reading’ - Resistance 4853.1Ω
[12:20:44][D][sensor:092]: ‘temp_resistance_reading’: Sending state 4853.11182 Ω with 1 decimals of accuracy
[12:20:44][D][ntc:026]: ‘Smart Plug Temperature’ - Temperature: 45.5°C
[12:20:44][D][sensor:092]: ‘Smart Plug Temperature’: Sending state 45.50340 °C with 1 decimals of accuracy
[12:20:49][D][api.connection:583]: Client ‘Home Assistant 0.102.3 (192.168.1.200)’ connected successfully!
[12:20:54][D][adc:056]: ‘temp_analog_reading’: Got voltage=0.44V
[12:20:54][D][sensor:092]: ‘temp_analog_reading’: Sending state 0.43555 V with 2 decimals of accuracy
[12:20:54][D][resistance:037]: ‘temp_resistance_reading’ - Resistance 4865.7Ω
[12:20:54][D][sensor:092]: ‘temp_resistance_reading’: Sending state 4865.67578 Ω with 1 decimals of accuracy
[12:20:54][D][ntc:026]: ‘Smart Plug Temperature’ - Temperature: 45.4°C
[12:20:54][D][sensor:092]: ‘Smart Plug Temperature’: Sending state 45.42505 °C with 1 decimals of accuracy
[12:21:00][D][sensor:092]: ‘Smart Plug Active Power B’: Sending state -0.01299 W with 1 decimals of accuracy
[12:21:00][D][sensor:092]: ‘Smart Plug Active Power A’: Sending state 0.07792 W with 1 decimals of accuracy
[12:21:00][D][sensor:092]: ‘Smart Plug Current B’: Sending state 0.01773 A with 2 decimals of accuracy
[12:21:00][D][sensor:092]: ‘Smart Plug Current A’: Sending state 0.01773 A with 2 decimals of accuracy
[12:21:00][D][sensor:092]: ‘Smart Plug Voltage’: Sending state 123.33615 V with 1 decimals of accuracy
[12:21:04][D][adc:056]: ‘temp_analog_reading’: Got voltage=0.44V
[12:21:04][D][sensor:092]: ‘temp_analog_reading’: Sending state 0.43652 V with 2 decimals of accuracy
[12:21:04][D][resistance:037]: ‘temp_resistance_reading’ - Resistance 4878.2Ω
[12:21:04][D][sensor:092]: ‘temp_resistance_reading’: Sending state 4878.24854 Ω with 1 decimals of accuracy
[12:21:04][D][ntc:026]: ‘Smart Plug Temperature’ - Temperature: 45.3°C
[12:21:04][D][sensor:092]: ‘Smart Plug Temperature’: Sending state 45.34689 °C with 1 decimals of accuracy
Hope this helps.
Hi @edboston,
Thanks for trying the code!, and I’m glad I could help you. I have a question, the values shown and the consumption of each channel are correct?
Didn’t see a reply to this until today. I had to fudge the values around to get them to match another sensor for voltage. I also played around with the values for power and current to get them to match the values of the device (LED bulb) specs.
Just stumbled upon this thread… is anyone got any updates or improvements on the esphome code. I’m wanting to flash some shelly 2.5 and shelly 1.0 relays.
Does anyone have the code for shelly 1.0 to save me sometime?
Edit found this code for Shelly 1
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: "f"
  password: !secret wifipassword
# Enable logging
logger:
api:
  password: !secret password
ota:
output:
  - platform: gpio
    pin: GPIO4
light:
  - platform: binary
    name: "Lampe Wohnzimmer"
    output: gpio_4
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO5
      #mode: INPUT_PULLUP
      #inverted: True
    name: "Schalter Wohnzimmer"
    on_state:
      - light.toggle: lightid
    internal: true
If you mean the 1PM this is one of mine:
  - platform: hlw8012
    cf_pin: GPIO05
    cf1_pin: GPIO13
    sel_pin: GPIO14
    power:
      unit_of_measurement: W
      icon: mdi:flash-circle
      accuracy_decimals: 0
      filters:
      - lambda: if (x < (2 + 1)) return 0; else return (x - 1);
    update_interval: 3s
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO4
      inverted: false
    on_press:
      - light.turn_on: light
    on_release:
      - light.turn_off: light
output:
  - platform: gpio
    pin:
      number: GPIO15
light:
  - platform: binary
    output: relay1
status_led:
  pin:
    number: GPIO0
    inverted: True
Or the Shelly 1:
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO5
      inverted: false
    on_press:
    on_release:
output:
  - platform: gpio
    pin:
      number: GPIO4
light:
  - platform: binary
    output: relay
Or the Shelly 2.5:
output:
  - platform: gpio
    pin:
      number: GPIO4
  - platform: gpio
    pin:
      number: GPIO15
light:
  - platform: binary
    output: relay1
fan:
  - platform: binary
    output: relay2
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO13
      inverted: false
    on_press:
      - light.turn_on: bathroom_light
    on_release:
      - light.turn_off: bathroom_light
i2c:
  sda: GPIO12
  scl: GPIO14
  - platform: ade7953
    voltage:
    name: Bathroom Light Fan Voltage
    current_a:
      name: Bathroom Fan Current
      filters:
        - lambda: if (x < 0.1) return 0; else return (x);
    current_b:
      name: Bathroom Light Current
      filters:
    active_power_a:
      name: Bathroom Fan Power
      filters:
        - lambda: if (x < 1) return 0; else return (x);
    active_power_b:
      name: Bathroom Light Power
      filters:
        - multiply: -1
    update_interval: 5s
Hi Edward:
Could you share with me for ESPhome yaml of shelly2.5?
I can not pass valid yaml.
Tks
Leo Yang
Here is the configuration I am using to control my shop lights (inside and outside lights)
substitutions:
  device: shop_light
  SSID: !secret SSID_NoT
  SSID_PWD: !secret SSID_NoT_pwd
  IP_Addr: 192.168.30.32
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: ${SSID}
  password: ${SSID_PWD}
  ap:
    ssid: "${Name} Fallback Hotspot"
    password: !secret WIFIpwdFallback
#  manual_ip:
#    static_ip: ${IP_Addr}
#    gateway: 192.168.1.1
#    subnet: 255.255.255.0
#    dns1: 192.168.1.1
time:
  - platform: homeassistant
captive_portal:
# Enable logging
logger:
api:
ota:
web_server:
  port: 80
i2c:
  sda: GPIO12
  scl: GPIO14
  - platform: ade7953
    voltage:
    current_a:
      name: ${Name} Current B
    current_b:
      name: ${Name} Current A
    active_power_a:
      name: ${Name} Active Power B
      filters:
        - multiply: -1
    active_power_b:
      name: ${Name} Active Power A
      filters:
        - multiply: -1
  # NTC Temperature
  - platform: ntc
    name: ${Name} Temperature
    calibration:
      b_constant: 3350
      reference_temperature: 298.15K
    resistor: 32kOhm
  - platform: adc
    pin: A0
status_led:
  pin:
    number: GPIO0
    inverted: yes
output:
  - platform: gpio
    pin: GPIO4
  - platform: gpio
    pin: GPIO15
light:
  - platform: binary
    output: ${device}_relay1
  - platform: binary
    output: ${device}_relay2
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO13
      #mode: INPUT_PULLUP
      #inverted: True
    name: "${Name} Switch Inside"
    on_state:
      then:
        - light.toggle: ${device}_inside
    internal: true
  - platform: gpio
    pin:
      number: GPIO5
      #mode: INPUT_PULLUP
      #inverted: True
    name: "${Name} Switch Outside"
    on_state:
      then:
        - light.toggle: ${device}_outside
    internal: true
You may have to play around with some of the resistor settings to get the voltage/power values correct for your unit.
thanks a lot for sharing
What should you adjust for better voltage / power readings? Today I flashed my shelly 2.5 to ESPHome but the power sensors show very strange values.
On the Power B entity, I’ve a light of 50W …
I had partly the same problem. Only that the value was negative, I did not have the value multiplied by 10.
To solve my problem I had to comment out the filter on active_power_a (which is for Active Power B in Home Assistant)
  - platform: ade7953
    voltage:
    current_a:
    current_b:
    active_power_a:
#      filters:
#        - multiply: -1
    active_power_b:
      filters:
        - multiply: -1
I suggest you try with this code and see if that solves your issue. Do a test with different known loads to confirm.
  - platform: ade7953
    voltage:
    current_a:
    current_b:
    active_power_a:
      # Multiply by positive 0.1 to try to correct wrong values
      filters:
        - multiply: 0.1
    active_power_b:
      filters:
        - multiply: -1
