This might take us somewhere…
Current best way:
“Install” Car Stats Viewer
Create a webhook to push information from “Car Stats Viewer” to HA
Following the hint above about the Car Stats Viewer app, which I had completely missed, I have been able to get information about my Polestar 2 in to HA. A lot of the info is in German (as the app is from Germany), but this is the process.
Sign up for a Test Track. The current list of tracks is here: CarStatsViewer Informationen - Polestar Wiki - Polestar Club (Google Translate will work on that page). Use the Google Account attached to your car.
Wait. I got a notification when I was added to the list, but you may not. Either way, you have to wait at least 24 hours before you can download the app. If you do get a notification, wait another 24 hours.
On your desktop, use the link supplied to accept the invitation and then use the option within Google Play to install the app on to your car. This shouldn’t take long.
In the car, you can find the app and configure it appropriately.
In Home Assistant, create a new template file:
templete:
- trigger:
- platform: webhook
local_only: false
webhook_id: averysecurecode
- name: "Polestar 2 Altitude"
state: "{{ trigger.json.alt }}"
unit_of_measurement: 'm'
icon: mdi:altimeter
- name: "Polestar 2 Temp"
state: "{{ trigger.json.ambientTemperature }}"
icon: mdi:thermometer
unit_of_measurement: 'c'
- name: "Polestar 2 Battery Level"
state: "{{ trigger.json.batteryLevel }}"
icon: mdi:battery
unit_of_measurement: 'w'
- name: "Polestar 2 Charge Port Connected"
state: "{{ trigger.json.chargePortConnected }}"
icon: mdi:ev-plug-type2
- name: "Polestar 2 Ignition State"
state: "{{ trigger.json.ignitionState }}"
icon: mdi:car-key
- name: "Polestar 2 Latitude"
state: "{{ trigger.json.lat }}"
icon: mdi:latitude
- name: "Polestar 2 Longitude"
state: "{{ trigger.json.lon }}"
icon: mdi:longitude
- name: 'Polestar 2 Current Power'
state: "{{ trigger.json.power }}"
unit_of_measurement: 'mW'
icon : mdi:speedometer
- name: "Polestar 2 Gear"
state: "{{ trigger.json.selectedGear }}"
icon: mdi:car
- name: 'Polestar 2 Speed m/s'
state : "{{trigger.json.speed}}"
unit_of_measurement: 'm/s'
icon: mdi:car-speed-limiter
- name: 'Polestar 2 SOC'
unit_of_measurement: '%'
state: "{{ trigger.json.stateOfCharge }}"
icon : mdi:car-electric
- name: "Polestar 2 Timestamp"
state: "{{ trigger.json.timestamp }}"
icon: mdi:clock-time-eight-outline
Change the webhook_id to something of your own. Remember that you will have to type it in on the car, so make it easy to type. I usually use Word.Word.Word (three words with a period between).
The above is based on a post in the German forum, but the values were incorrect, so I have adjusted them.
Do a refresh of template entities in Developer tools, and verify you have a number of sensors starting Polestar2 with an unknown value.
Back to your car. The URL you need to enter in the webhook depends on how you are exposing HA to the internet.
If it is direct, then enter the value thus:
https://hostname:8123/api/webhook/averysecurecode
If you are using Nabu Casa, then you need to enable it in the Home Assistant Cloud config. It will be called something like "Trigger Update Coordinator (template) and choose to enable it. This will give you a URL. You need to get that URL to the car. It is a bit long to type, so what I did was email it to a webmail account, then open the account using Vivaldi browser and then copy and paste the URL in to the app.
Make sure that you enable the API and enable location tracking etc.
Once values are coming back to HA, you can do some more work in HA…
To use the location information, create a new Automation - just create the automation, switch to YAML view and then copy and paste:
alias: "Polestar: CSV Location"
description: ""
- platform: state
entity_id:
- sensor.polestar_2_latitude
- sensor.polestar_2_longitude
condition: []
- service: device_tracker.see
dev_id: polestar_csv
gps:
- "{{ states('sensor.polestar_2_latitude') }}"
- "{{ states('sensor.polestar_2_longitude') }}"
mode: single
That is a very basic entry, it can be expanded with other information such as the battery charge.
Conversion of some values to something more friendly?
sensors:
polestar2_speed_mph:
value_template: "{{ (states('sensor.polestar_2_speed_m_s') | float * 2.237) | round(1)}}"
unit_of_measurement: "mph"
friendly_name: "Polestar 2 speed MPH"
sensors:
polestar2_charge:
value_template: "{{ (states('sensor.polestar_2_soc') | float * 100 )}}"
unit_of_measurement: "%"
friendly_name: "Polestar 2 Charge"
sensors:
polestar2_power_kw:
value_template: "{{ (states('sensor.polestar_2_current_power') | float / 10000000) | round(2) }}"
unit_of_measurement: "kw"
friendly_name: "Polestar 2 Power kw"
Then finally a card to just show everything.
type: entities
entities:
- entity: sensor.polestar_2_altitude
- entity: sensor.polestar_2_temp
- entity: sensor.polestar_2_charge_port_connected
- entity: sensor.polestar_2_ignition_state
secondary_info: last-changed
- entity: sensor.polestar_2_latitude
- entity: sensor.polestar_2_longitude
- entity: sensor.polestar_2_current_power
- entity: sensor.polestar_2_gear
- entity: sensor.polestar_2_speed_m_s
- entity: sensor.polestar_2_soc
- entity: sensor.polestar_2_timestamp
- entity: sensor.polestar2_speed_mph
- entity: sensor.polestar2_charge
icon: mdi:car-electric
- entity: sensor.polestar2_power_kw
icon: mdi:speedometer
Map card works well, particularly with the auto_fit value.
Mini Graph Card is good for the altitude value.
Only bit I am missing is converting the timestamp to human readable format, but I have an open question elsewhere on this forum on how to do that.
So for anyone else following along, the last entry in the template for the timestamp should be changed to this:
state: "{{ trigger.json.timestamp | multiply(1/1000) | timestamp_local }}"
That will convert the last date and time of the update to something readable.
You can also add this line:
- name: "Polestar 2 Last Update"
device_class: timestamp
Which will give you a read out of the time the last update occured.
This is great, but somewhat complicated. HA in the car already exposes some of these sensors across the HA implementations (like location), could HA in the car be updated to expose all the same sensors that car stats viewer exposes?
As I understod it, it already does, but since you cannot get into the app settings in the car anymore ( after complain from google ) you cannot enable them. I thought this was only a temporary change but I seams permanent.
I would like to contribute on top of already excellent post by @scriven33
Changes:
- introduce binary_sensor for charge port
- extra attributes
- unique_id (so you can personalize in the UI)
template:
- trigger:
- platform: webhook
webhook_id: VERY_SECRET_ENDPOINT_THAT_IS_OPEN_TO_THE_INTERNET
local_only: false
unique_id: polestar_webhook
binary_sensor:
unique_id: p2_charge_port_connected
state: "{{ float(trigger.json.alt) if trigger.json.alt is defined }}"
availability: "{{ trigger.json.alt is defined }}"
icon: mdi:altimeter
unique_id: p2_altitude
state: "{{ float(trigger.json.lat) if trigger.json.lat is defined }}"
availability: "{{ trigger.json.lat is defined }}"
icon: mdi:latitude
unique_id: p2_latitude
state: "{{ float(trigger.json.lon) if trigger.json.lon is defined }}"
availability: "{{ trigger.json.lon is defined }}"
icon: mdi:longitude
unique_id: p2_longitude
unit_of_measurement: '°C'
unique_id: p2_ambient_temperature
state: "{{ trigger.json.batteryLevel | float(0) / 1000 }}"
icon: mdi:battery
unit_of_measurement: 'kWh'
device_class: energy
unique_id: p2_battery_level
icon: mdi:car-key
unique_id: p2_ignition_state
state: "{{ trigger.json.power | multiply(1/1000000) }}"
unit_of_measurement: 'kW'
device_class: power
unique_id: p2_current_power
icon: mdi:car
unique_id: p2_gear
- name: 'Polestar 2 Speed km/s'
state : "{{trigger.json.speed | float(0) * 3.6 }}"
unit_of_measurement: 'km/h'
unique_id: p2_speed
state: "{{ trigger.json.stateOfCharge | float(0) * 100 }}"
device_class: battery
unique_id: p2_soc
unique_id: p2_timestamp
Automation to update location:
description: ""
- platform: state
entity_id:
condition:
- condition: not
conditions:
- condition: or
conditions:
- condition: state
entity_id: sensor.polestar_2_latitude
state: unavailable
- condition: state
entity_id: sensor.polestar_2_longitude
state: unavailable
alias: Any will do
alias: Neither Latitude or Longitude can be Unavailable
gps:
dev_id: polestar
mode: single
Those are some great modifications. Thanks for updating my work - mine was very much early stages and needed cleaning up, as I knew it could be done better.
I prefer the sensor for the Charge Port Connected, as it states True, which I think is more true to life.
Your modifications also allowed me to remove some of the additional templates I created as well.
Are you on the International Polestar Forum? If so, you might want to post your mods on there as well.
Not an active user there.
Feel free to link from there to here (thus avoiding duplication)
I just want to leave this here:
It seems some heros have developed exactly what we are all looking for, but for the Volvo environment. I think it would just be a matter of branching this to Polestar and we’re all set (with a rock solid integration not relying on 3rd party integrations and intermediary apps).
Perhaps someone here could port it? Alternatively help me petition the creator to help branch their creation to the Polestar environment!
Cheers
//S
AFAIK we do not share the same backend
Do you have access to your car information through a webpage ? Like volvo’s do ?
Clearly there is an API since companies like Tibber can develop functionalities towards it (Polestar Smartladdning – Ladda din Polestar smart ⚡️ Tibber), but it’s likely not public.
The only access I have, as you well know, is through the Polestar App.
edit: my thought was the Polestar API likely shares a similar internal structure to the VCC API.
A new version of Car Stats Viewer has been released, although it isn’t on all of the tracks. New functionality in the API, but the old one works as before.
Hi @scriven33
I am using your templates and stuff in Home Assistant. They mostly work great but I don’t seem to get any Lat Long or Altitude data. I’ve checked ABRP is working and the blue connection icon shows in CSV. Any ideas?
Have you enabled the option in CSV in the car to send that information? I am sure it is a toggle (not with the car right now).
Seeing this makes me sad that Polestar doesn’t offer the same things for us. The platforms are the same but the backends are different, so this wont work for us. Look at all the things they get directly with the Volvo API:
VEHICLES_URL = “https://api.volvocars.com/connected-vehicle/v1/vehicles”
VEHICLE_DETAILS_URL = “https://api.volvocars.com/connected-vehicle/v1/vehicles/{0}”
WINDOWS_STATE_URL = “https://api.volvocars.com/connected-vehicle/v2/vehicles/{0}/windows”
CLIMATE_START_URL = “https://api.volvocars.com/connected-vehicle/v2/vehicles/{0}/commands/climatization-start”
CLIMATE_STOP_URL = “https://api.volvocars.com/connected-vehicle/v2/vehicles/{0}/commands/climatization-stop”
LOCK_STATE_URL = “https://api.volvocars.com/connected-vehicle/v2/vehicles/{0}/doors”
CAR_LOCK_URL = “https://api.volvocars.com/connected-vehicle/v2/vehicles/{0}/commands/lock”
CAR_UNLOCK_URL = “https://api.volvocars.com/connected-vehicle/v2/vehicles/{0}/commands/unlock”
RECHARGE_STATE_URL = “https://api.volvocars.com/energy/v1/vehicles/{0}/recharge-status”
ODOMETER_STATE_URL = “https://api.volvocars.com/connected-vehicle/v2/vehicles/{0}/odometer”
LOCATION_STATE_URL = “https://api.volvocars.com/location/v1/vehicles/{0}/location”
TYRE_STATE_URL = “https://api.volvocars.com/connected-vehicle/v2/vehicles/{0}/tyres”
ENGINE_STATE_URL = “https://api.volvocars.com/connected-vehicle/v2/vehicles/{0}/engine-status”
BATTERY_CHARGE_STATE_URL = “https://api.volvocars.com/connected-vehicle/v2/vehicles/{0}/battery-charge-level”
FUEL_STATE_URL = “https://api.volvocars.com/connected-vehicle/v2/vehicles/{0}/fuel”
STATISTICS_URL = “https://api.volvocars.com/connected-vehicle/v2/vehicles/{0}/statistics”
ENGINE_DIAGNOSTICS_URL = “https://api.volvocars.com/connected-vehicle/v2/vehicles/{0}/engine”
VEHICLE_DIAGNOSTICS_URL = “https://api.volvocars.com/connected-vehicle/v2/vehicles/{0}/diagnostics”
I’m jealous.
I’m going to try to host my own test version of CSV and then push to HA, guess that’s our best bet today.
This works pretty well. I have added a Charger Status indicator to my EV page, and I’m calculating the estimated SOC based on how many kWh were added to the starting battery level and divided by the battery capacity.
At home, when plugging in the charger before locking the car, the data gets sent to HA properly. When done charging, unlocking the car will get the information sent to HA.
The left battery bar is the estimated SOC, the right bar is the actual data coming from the car. I took the screenshot after going out to the post office, but they did match when the car first reported its level back.
I tried this setup via tibber (free account without energy contract), works pretty good!
Similar solution via bash script has already been mentioned above:
How does Tibber obtain the information? Does it have a connection to the Polestar API?
