Integration of Polestar 2
And how can you then use that account to create a developer account? Because the sign up screen will only show following options… and that is not the VOLVO ID.
Do you have some more details on the process?
I got it working now, I’ve created a Volvo account and used this for the integration, not the login for developer.
so email and password Volvo account and API key from developer site.
Thx, that did the trick for me too!!
I’ve deleted the icon: line in the custom_components/polestar_api/sensor.py file for the soc description.
this way the battery lvl in the icon corresponds to the actual lvl.
i’ll create an update with remove that icon, you can also put a new MR in the future if something could change.
great work bro, thank you, much appreciated!
any change to get the charge limit entity too?
i didn’t find the api where i can get this value
I’m using the data here:
Do I need to do something myself to get correct wording for the charging connection?
you can do this in a template or in a custom button card.
I do this for the descriptions of my charger.
These are value that i need to add, i’ll add this one, i didn’t get that value yet
@Depechie can you download this latest version:
should normally fix this long text
there is a typo tho,
shit… just updated
I guess there will be a CONNECTION_STATUS_CONNECTED_DC": “Connected DC” too than?
could be. but once someone gets me a screenshot of it, then I’ll add them.
or if someone finds an API spec results of this, then I can add them. otherwise, I need to add too much guess value.
but open then an issue on github so I can add them in the Integration.
(at the moment I look here for feedback, but couldn’t continues read this thread)
OK when I have the time, I will do some tests charging the vehicle.
(I just noticed another typo in the word “disconnected”, 1 n missing.
done the change now
It would be best to split the API into a separate Python library for future core integration
I tried both with my Volvo account and the Developer account, but still nothing.
Just unknown states and calls being made to the API.
Any suggestions?
Edit: Hm…it seems to be working now. I guess I just needed to give it some time.
Now if we could just find a way to activate the climate control, we’d be set!
